Results 1 to 7 of 7
Thread: What size sediment screen for my deep well pump?
    DIY Member Timbuktu's Avatar
    Jun 2012
    PalmSprings SCal
    Default What size sediment screen for my deep well pump?
    One of these days my deep well submersable will fail and require a "well man" to pull'er up.
    So i can be prepared for that day I should be researching now ,the kind of sediment filter that id have them replace the current one with. Thats assuming i have a "mesh size " choice .
    Of course theres no way of knowing what smaller size i need unless I know whats on it now.
    You know,I did save some sand that came up a few days ago,so i could take that sample into a dealer who could size the mesh using my sand sample. right?
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    If you have course sand, sometimes it is better to use two filters. A large one with a course screen ahead of one with a finer screen.
    Jun 2012
    PalmSprings SCal
    I assume there is supposed to be a sort of screen filter where the water first enters the well pipe down below.
    Is there a place online you may know of where I can see whats available ?
    or.. Is it better just to wait until the pump fails and has to be pulled up. Then whoever i call out to pull up the pump will be able to recommend a new filter screen then.?
    Mar 2006
    Lubbock, Texas
    Good well casing with screen or perfs should be the screen that keeps sand out of the well. But if it pumps sand, then you have to filter above ground. Lakos makes a seperator that fits on the pump. But you will need some open hole below the pump for it to drop the sand into.
    Feb 2011
    NW Ontario, Canada
    Is this a mud or rock bore? A rock bore would not use screened casing. If a rock bore, it might be top fed so putting a sleeve on the pump may help.
    If it is a mud bore, the well may need some further development by heavy over-pumping. That said, some wells may never clear up and so a dole valve and in-line filters might be the only option.
    Jun 2012
    PalmSprings SCal
    I have no idea. Im in decomposed granite. High desert mountains. Never seen mud here,plenty of rock and sand.
    DIY Junior Member lebatard's Avatar
    Jun 2012
    New York
    I agreed with the 2 screen idea. First use the more coarse screen as a first layer of protection and behind that, use a very fine wire mesh. Try something like a 100 x 100 stainless steel wire mesh that might be found here:
    http://www.bwire.com/
    These 2 layers of screening and filtration should be enough to keep both large and small sediment from causing this catastrophe that you are preparing for. Cross your fingers and hope you have a lot of time before this occurs.
  1. Sediment problems - how deep should I place the pump?
    By Joelk in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-23-2012, 04:55 PM
  2. driven well point screen / slot size question
    By too old for this in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-17-2010, 06:07 PM
  3. Deep Well Pump Size??
    By rman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-04-2010, 05:41 PM
  4. how do I determine the WELL POINT SCREEN SIZE
    By KHB1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-14-2008, 06:40 AM
  5. Sediment particulate size test?
    By Greg Mueller in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-27-2007, 07:40 AM
