Results 1 to 10 of 10
Thread: Need help identifying faucets
    DIY Junior Member MEYLIN's Avatar
    Jun 2012
    Colorado
    Default Need help identifying faucets
    See photos of mini widespread and 8 inch widespread faucets. Any help identifying the manufacturer would be greatly appreciated!
    Those designs are almost generic with the various "custom" manufacturers. They could be California Brass, Artistic Brass, or any of a dozen other brands, many of them out of business. A photo of the stem will often identify who made the basic unit, but not always who added the artistic design to it.
    Jun 2012
    Colorado
    See attached photos of faucet stems. Any idea who made the basic unit?
    In the lower photo, the spout reminds me of American Standard Jasmine, but I don't think the handles are right for that. The cartridge could be AS, similar to 994053-0070A
    Jun 2012
    Colorado
    After months of research, I may have found the manufacturer of the widespread stems... Brasstech Faucet Part (FLU-4685 and 4686). My question is whether I can replace faucets with a trim kit made by Brass Tech?
    Brasstech is not a faucet brand per se, it is a conglomerate. http://www.brasstech.com/ Your faucet is a dated design, and the availabilty of trim is doubtful.
    Jun 2012
    Colorado
    Plan would be to replace entire faucet on two sinks and roman tub. Replacing valve on the roman tub would be difficult and requires removing tile. Would a Newport Brass trim kit work on existing valve?
    The core problem is that most of those Roman tub spouts are integral with the deck, ( unless it is secured with an Allen screw on the back of it), and can only be changed by accessing the area underneath the deck which would reqire tile removal. The sinks can use ANY faucet that you feel has a compatible look to it.
    Jun 2012
    Colorado
    No allen screw on the spout it would require tile removal. Newport Brass trim is more expensive than replacing with Delta faucet and valve. Any reason to stay with Newport Brass?
    The ONLY reason anyone would buy Newport Brass, or any other similar faucets, is for the looks.
  1. Help identifying old fitting
    By abargnesi in forum Plumbing Forum Discussion & Blog
    Last Post: 02-14-2012, 04:39 AM
  2. Help identifying DWV pipe
    By CM2304 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-11-2012, 11:51 AM
  3. Help in identifying fixtures
    By dgtldan in forum Shower & bathtub Forum & Blog
    Last Post: 10-19-2009, 03:06 PM
  4. I need help Identifying a Toilet lol
    By Neotonic in forum Toilet Forum discussions
    Last Post: 10-27-2008, 12:57 PM
  5. need help identifying a tool
    By r_2016 in forum Electrical Forum discussion & Blog
    Last Post: 04-30-2008, 03:55 AM
