Results 1 to 8 of 8
Thread: Newbie question - Briggs toilet supply
    DIY Junior Member smarchitelli's Avatar
    Jun 2012
    Toronto, ON
    Default Newbie question - Briggs toilet supply
    Hi Guys,
    Let me start off that I am the world’s worst handyman, so please be gentle. I have a problem with one of my toilets in my home. It is a Briggs – R 7424. It seems to be leaking where the arrow indicates (see attached pic). Any recommendations on the replacement line? A guy I work with mentioned the Watts Floodsafe products, but a quick review online wasn’t very favorable.
    Please let me know and any advice would be greatly appreciated.
    Steve
    With a high volume one-piece toilet, you won't want the Flood Safe supply.
    I would remove the existing supply tube with the lower nut and match it up at a hardware store.
    It's a little hard to tell from the drawing, but it looks to be either a 3/8" comp or a 1/2" comp. On the West Coast, we use a 1/2" from the wall with a 3/8" supply line. but I know that the East Coast likes 3/8".
    You can also use rigid pipe there if you feel handy.
    Jun 2012
    Toronto, ON
    Ok, I will try that. Thanks for the advice. Any particular brands I should be looking for the supply tube? Would it include the top plastic screw nut as well?
    The top nut is a standard 7/8" for a toilet fill valve.
    Brands? It will depend on what they have. I have my preference, and they bring them in specially for me.
    Jun 2012
    Toronto, ON
    Would a braided line be ok or do I have to use a solid pipe like the original fitting?
    Apr 2012
    New York, NY
    Quote Originally Posted by smarchitelli View Post
    Get the braided line. No reason not to use it. It won't be a straight run like that pipe; you will likely loop it to fit and that's fine. You can look at any toilet anywhere to see how they have done it; around where I live, at least 50 percent have replaced that little pipe with a braided line.
    And when you're done, you will feel just a little bit handier!
    Braided lines come in various lengths. Don't shoot for an exact fit, allow a little extra for fitting. Only problem with lines that are way too long is they have to be looped and are not very attractive, but they work.
    Aug 2009
    South*East
    Take a close look at the nut that connects the supply tube to the fill valve it appears to be cracked.
    John
  1. Question about water supply pipe location for toilet
    By garlandk77 in forum Toilet Forum discussions
    Last Post: 12-01-2010, 07:43 AM
  2. Replace tank on older 1.6gpf Briggs toilet or buy new toilet?
    By brennok in forum Toilet Forum discussions
    Last Post: 03-05-2010, 06:57 AM
  3. Briggs, Flush valve or flapper for old Briggs?
    By Guest in forum Toilet Forum discussions
    Last Post: 11-12-2008, 07:16 AM
  4. Newbie Question: Toilet Install
    By DerekW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2008, 04:04 PM
  5. briggs toilet
    By huskerfan in forum Toilet Forum discussions
    Last Post: 07-10-2007, 08:37 AM
