Results 1 to 4 of 4
Thread: Three way switch wiring trouble
    DIY Junior Member wmlaveck's Avatar
    Jun 2012
    Fort Wayne, IN
    Question Three way switch wiring trouble
    My home is 50 years old and uses a fuse box. I have a stairway that uses two three way switches to control one light. They were starting to fail so I purchased two replacement switches. When I removed the old witches I did not see any labeling as to common so I disconnected all wires from both switches. My first attempt to wire blew the fuse and same with second attempt.
    After doing some research on wiring three way switches and troubleshooting, I did some testing. Using a volt meter I connected one lead to a ground and used the other lead to find the hot. Here is what I found:
    Outlet box A
    Black wire 120v
    Red wire 51v
    White wire 0v
    Outlet box B
    Black wire 120v
    Red wire 51v
    White wire 0v
    Can anyone help me to make sense out of this? It is my understanding that I should only find one hot wire out of the two sets of three wires and I have no idea how I am getting 51v AC from the red wires.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by wmlaveck View Post
    When I removed the old witches...
    Witchcraft.
    Either you have the red in series with the load or it's phantom voltage from induction.
    Jun 2012
    Fort Wayne, IN
    So what is the solution? I am thinking that the neutral should not be connected as it is. If I replace the boxes I’ll have room to rewire them correctly.
    Mar 2011
    Houston, TX
    So what is the solution? I am thinking that the neutral should not be connected as it is. If I replace the boxes Iíll have room to rewire them correctly.
    Take one of the old switches to a store so that you can get a direct replacement.
    Some of the connections on a new switch may look the same but the connections may be different.
    Is it a SPDT or a DPST or a DPDT ?
  1. 3-way switch wiring
    By sucosam in forum Electrical Forum discussion & Blog
    Last Post: 10-14-2009, 05:48 AM
  2. wiring a three way switch....
    By rtstephn in forum Electrical Forum discussion & Blog
    Last Post: 06-14-2008, 09:23 PM
  3. wiring 2 way switch
    By zajnbou in forum Electrical Forum discussion & Blog
    Last Post: 12-24-2007, 07:22 PM
  4. Wiring Trouble
    By jperna in forum Electrical Forum discussion & Blog
    Last Post: 11-14-2007, 05:14 AM
  5. Weird Switch wiring
    By ms21117 in forum Electrical Forum discussion & Blog
    Last Post: 08-14-2007, 09:40 AM
