Results 1 to 3 of 3
Thread: Trouble with 1" nipple onto 1" 200 psi poly tubing
    DIY Junior Member grizz's Avatar
    Jun 2012
    Colorado
    Default Trouble with 1" nipple onto 1" 200 psi poly tubing
    I'm having a little trouble trying to fit a 1" brass nipple onto my 200 psi poly tubing. Is it ok to heat up the poly tubing with a torch to get the fitting on? The tubing is blue on the outside and white on the inside. If heating is ok, should I heat both the outside and inside of the poly tubing?
    Feb 2011
    NW Ontario, Canada
    I use a heat gun and make it just hot enough that it still takes effort to get it on.
    Dec 2009
    northfork, california
    Agreed - and good effort. If it gets too hot it de-cross links and later you get a lost pump. Hot water is best, but even a hair dryer will work. Use GOOD clamps, 3 and install them while its still warm - retorque them a bit later with a nut driver, not a screwdriver.
  1. 1/2" Depth Split Escutcheon Cover for 1/2" Pex Tubing
    By wwsmith in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2011, 08:25 AM
  2. Betta Flo and 1 1/4" poly???
    By MATTHEW1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-25-2010, 05:39 AM
  3. 1/2" Copper to 1/4" Plastic Tubing
    By kristof in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-24-2009, 07:24 AM
  4. 1" poly pipe
    By v1rtu0s1ty in forum Irrigation / Sprinkler Forum
    Last Post: 07-03-2008, 01:11 PM
  5. Poly Pipe - 1" vs. 3/4"
    By dsk in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-13-2006, 08:32 AM
