Results 1 to 7 of 7
Thread: Wire and pipe broken off well pump
    DIY Junior Member chrd00's Avatar
    Jun 2012
    PA
    Default Wire and pipe broken off well pump
    After no water pressure and power inside, went out to the pump. wires broken and no pipe either. Any thoughts on how to get the pump out..or could we leave it in and put in a new pump?
    Jul 2005
    Marin Co. Ca.
    You may not want to hear this, But You need a well Pro. Good luck
    Feb 2011
    NW Ontario, Canada
    Maybe you got lucky and someone stole your pump. A little more info would help but as toolaholic mentioned, you need a pro before you make a bad situation worse. This is no time for DIY.
    Dec 2009
    northfork, california
    If its deep enuf and the lost pumps not new set a new one a few feet over the old one.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by ballvalve View Post
    ...set a new one a few feet over the old one.
    I'm going on the assumption that the pipe broke off at the top and that there is now a lot of pipe sticking up above the pump precluding the OP from setting a new pump a few feet over the old one.
    Now assumptions are all we have to go on since the OP makes no mention of the size of casing, depth of well, pitless or sanitary seal, etc. Maybe he got lucky and the pump unscrewed itself from the bottom of the pipe, and all the pipe is still hanging from the pitless.
    Jul 2005
    Marin Co. Ca.
    Well ,You could have someone run a camera down the casing, and try fishing with a snear. You would need to disinfect the camera head and cable 1st
    Also disinfect Your well after. Folks in the well business have past experience with this and are invaluable to You. Also, If You can find a well Pro with a camera, it may only have been used ,in wells only and be clean . Good luck
    Mar 2011
    Houston, TX
    I have heard everything now.
  1. 11 yr old drop pipe and wire reusable on 220ft pump swap......?
    By xlr8tion in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-14-2012, 03:08 PM
  2. Broken Pipe
    By flightline23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2008, 06:09 AM
  3. Broken well pipe
    By grassdog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-23-2008, 03:59 PM
  4. hot water pipe near elec.wire
    By pipewoe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2007, 05:31 AM
  5. Broken pipe on tub spout
    By TMO in forum Shower & bathtub Forum & Blog
    Last Post: 12-21-2004, 05:40 PM
