Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: 3" threaded brass wye fitting?
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Default 3" threaded brass wye fitting?
    Hello!
    I noticed this in a picture I took of a house I am buying.... is this a 3" threaded brass wye? Would it be common for the female end (inserted into that hub coming out of the floor) to be threaded?
    The 3" copper goes off to an addition that houses a half bath. I can't quite figure out what was here before the addition. Maybe just a clean-out?
    It has to come out to fix that laundry drain going to the floor drain...
    Thx!
    Nov 2010
    Maine
    It's a clean out, and it's cast iron not brass. Only the plug and the reducing coupling going into it are brass.
    Aug 2009
    South*East
    I would be more concerned with the laundry tub being hooked up to the floor drain.
    John
    Aug 2005
    Columbus, OH
    Well, that's a bummer. I thought that maybe when it came out it might be worth a buck. Thanks.
    Quote Originally Posted by johnjh2o1 View Post
    Did you see this part?
    Quote Originally Posted by Lakee911 View Post
    Nov 2010
    Maine
    A little less than a buck but close
    Afer it "comes out", how are YOU going to connect the laundry sink. It will NOT be a job for a PVC or ABS replacement.
    Aug 2005
    Columbus, OH
    I'm going to remove the wye and install a new wye with a donut into the existing hub. That wye will either be a 3"x3"x2" and connect over to the sink and washer, or I might find that I need to remove that 45deg down to the wye laying horizontally in the floor if I have too much height. I'll place another wye on top and connect over to the 3" copper pipe, which has plenty of slope, with a banded coupling. I'll add a new vent to the laundry sink and washer. If I can tie into an existing vent I will, or I'll use a AAV. This isn't the main stack for the house--that's a bit to right upstream of this and out of the picture. Thoughts?
    Jason
    You CANNOT raise the connection for the 3" copper line, and if you stack another tee on top of it, it will be too high for the laundry sink.
    Aug 2005
    Columbus, OH
    But I can! I'll have to cut it back first ... there is plenty of slope outside of the picture. Its coming down from a bath one story up. I'll connect the sink low enough so it will drain (thus removing the existing wye and mabe the 45).
    Suppose I couldn't though...how about a double wye or a side outlet wye?
    When I take possesion of the house, I will measure carefully before cutting...
    Jason
    There are several fittings, you COULD use, but it depends on what the stores in your area have. Good luck finding a "side inlet Y" because I have never seen one.
    Aug 2005
    Columbus, OH
Size:  3.6 KB I bet no one stocks it. LOL
    I can imagine the joy in the factory when they got your order. "Attention everybody. We just got an order for a side inlet Y, so we have to stop whatever you are doing and convert over to that mold so we can make one for him. Once that is done put everything back to normal and continue with what you were doing". No catalog that I have ever seen has had that fitting as far as I know. But you would probably need a combo, NOT a "Y", anyway,
    Aug 2005
    Columbus, OH
    LOL I am not going to use it but I did find it on a popular website for less than a Jackson. It was, in fact, a '3" PVC DWV Wye and 45° Elbow Combo w/ 2" R Side Inlet.'
    If all goes well we close on Aug 10 so stay tuned....
    DIY Member kevink1955's Avatar
    Nov 2011
    L.I. New York
    Funny but in 2001 I replaced all the cast iron in my basement with PVC (the cast had rusted out). The top fitting just before the first floor level was a side inlet cast T/Y. Very common in my area.
    I went to a local supply house who has every PVC fitting ever made neatly aranged in bins, took a walk in the back and pulled the exact fitting I needed out of the bin. The place has since gone over to a bath show room, I wonder what happened to all those odd ball PVC fittings
    Side inlet TY, or sanitary tees are as common as flies, and almost every house installation uses at least one of them. Side inlet "Y"s or "combos either do not exist, or are so rare that they are unobtainable.
  1. Can I solder a copper to brass threaded connection?
    By Scott Vroom in forum Plumbing Forum Discussion & Blog
    Last Post: 07-29-2011, 10:50 AM
  2. Leaky threaded brass fiitting to shower valve
    By bbortnic in forum Plumbing Forum Discussion & Blog
    Last Post: 12-09-2009, 06:21 AM
  3. How tightly should [Gator|Shark]bite fittings be screwed to threaded brass?
    By miamicanes in forum Plumbing Forum Discussion & Blog
    Last Post: 11-12-2009, 10:43 PM
  4. brass to cast iron threaded connection leaks
    By sxotty in forum Plumbing Forum Discussion & Blog
    Last Post: 06-07-2009, 11:53 AM
  5. How tight - copper to brass threaded fittings
    By tfratzel in forum Plumbing Forum Discussion & Blog
    Last Post: 01-09-2005, 08:57 AM
