Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Does this quote make sense? Dual Shower w/ Body Sprays
  1. #16
    quote; What about a heat recovery pipe on the shower's cold water intake
    The water pipes are going in the attic, so I doubt that he has a basement, and I would NEVER install one of those under a concrete slab floor, even if I believed they gave a benefit, which I do not.
  2. #17
    DIY Junior Member zipsilver's Avatar
    Jun 2012
    Florida
    Quote Originally Posted by johnfrwhipple View Post
    Aside from all the pipe sizes comments the actual cost of the new work does not seem out of line. If your on a roll with the change orders you can consider a few more options.
    1). What about a heat recovery pipe on the shower's cold water intake? This can pre-warm the cold water reducing the demand on the hot while you shower.
    2). What about a secondary hot water tank to pre-heat the cold water for the master shower. This I have not seen done but something I want to do in my own home.
    3). A on demand hot water system for your en suite shower. Just in case you get all the flow you want and want to stay in the shower for more than 30 minutes.
    Just more food for thought.
    JW
    If the 50Gal Electric doesn't cut it with the vertical spa for at least a 10 minute shower I will probably put an 18KW EcoSmart on demand unit on the single rain shower head as a back up. Incoming water temp is 62-75 here in Cent FL
  3. #18
    Tankless might work out with your incoming water that tepid BUT some don't like it very warm if they can't modulate the flame down enough. Check the specs carefully.
  4. #19
    Jun 2012
    Florida
    Thanks, but flame? being fecisious? it is electric
  5. #20
    Nov 2009
    VA
    You may not even be able to add the electric tankless without an upgrade to your electrical service. You are adding an additional 18kW load that probably wasn't planned for when the house was built and you may not be able to support it.
  6. #21
    The modulation range on any tankless can vary, regardless of the source of heat. It's certainly eaiser to modulate with electric, but that doesn't mean that they can.
  1. Body Sprays in Shower
    By Frankie in forum Shower & bathtub Forum & Blog
    Last Post: 11-07-2013, 08:28 PM
  2. Does this make sense?
    By mark_g in forum HVAC Heating & Cooling
    Last Post: 04-13-2009, 03:23 PM
  3. does this make any sense
    By jburton32 in forum Electrical Forum discussion & Blog
    Last Post: 05-13-2008, 07:25 PM
  4. New Shower with body sprays - wrong mixing valve
    By mbeaver in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2008, 07:00 AM
  5. Multi-Shower Heads/Body Sprays
    By Lenny B in forum Shower & bathtub Forum & Blog
    Last Post: 01-11-2007, 01:11 PM
