Results 1 to 6 of 6
Thread: Toto Vespin II vs. Toto Aquia or CST416M#01 vs. CST474CEFG#01
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Toto Vespin II vs. Toto Aquia or CST416M#01 vs. CST474CEFG#01
    Hello,
    - I am trying to choose between the two toilets mentioned above. The primary goal is to avoid having a clogged toilet. I am considering these two because of the skirted appearance.
    - I like the look of the Aquia, but am not crazy about the push-button flush.
    - I like the height of the Vespin II, and the flush lever. Does the Vespin II perform as well as the Aquia?
    Thanks in Advance!
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Yakima WA
    Just select the toilet that you like. All Toto toilets perform well, so you can't really go wrong.
    The Aquia bowl has less standing water, a washdown rinse and standard glaze.
    It comes in 15-1/8"
    CST416M
    and 16-18" high bowls.
    CST412MF and CST464MF
    The Vespin has a larger water spot, standard with Sanagloss
    Bowl height on the discontinued CST764SG is 15-1/8"
    And for the Vespin II, CST474CEFG, 16-1/8"
    I lean toward the Vespin II, but it's a really close call between the two. I've sold a bunch of them all, and they do have their proponents.
    Apr 2012
    New York, NY
    You should go with what you like -- take a look at how they flush on Youtube. Me, I would go with the Vespin II due to no button flush and the fact that I love the double-cyclone rinse. Based on my experience discussed elsewhere with the Duravits, I'm not a fan of the washdown rinse on toilets like the Aquia, although I'm sure the Aquia's performance is better than our Duravits.
    Sep 2006
    cold new york
    Thanks for the replies!
    Questions regarding Vespin II:
    1. Longevity and Parts - Are there any known issues with maintenance, and are parts costly?
    2. Cleaning and Staining of Bowl - Are there any secrets to maintaining the sanagloss in order to preserve it? Are there any issues with permanent staining of the Bowl?
    Thoughts on Aquia: I like the appearance of the Aquia the most, hands down. However, I don't like the flush button of the Aquia. I like the additional height of the Vespin II, and I'm waiting to hear the verdict on the sanagloss feature. If sanagloss is a plus, why isn't it part of the Aquia?
    Thanks again
    Gore Vidal.
    The Vespin parts are common to the hardware stores.
    At Lowes it would be the Korky MaxPerformance fill valve and the Korky TOTO 3" replacement flapper.
    Sanagloss has been around a long time. I have it in three of mine. I just use a liquid cleaner on it. It does stay cleaner then the standard glazing.
    I kind of swap these things around. I have a Vespin II now where the Aquia was.
  1. Replies: 7
    Last Post: Today, 09:37 AM
  2. TOTO Aquia vs TOTO Drake vs Drake II vs Vespin II
    By Terry in forum Toilet Forum discussions
    Last Post: 07-24-2013, 09:22 PM
  3. TOTO Vespin II Expectations vs TOTO Carlyle
    By Arlington22207 in forum Toilet Forum discussions
    Last Post: 01-04-2011, 10:01 AM
  4. Difference? Aquia CST414M and CST416M
    By jbeach in forum Toilet Forum discussions
    Last Post: 10-17-2009, 09:14 AM
  5. Aquia model#cst416m
    By kfarhouna in forum Toilet Forum discussions
    Last Post: 10-02-2008, 11:24 AM
