Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Making Decora Wall Plate Look Good
    Jun 2009
    Canada
    Default Making Decora Wall Plate Look Good
    I'm having a hard time making a certain 3-gang decora-style wall plate look good.
    I did 1-gfci outlet, and 1-standard 15amp. outlet and the face of each of those stands proud of their wall plate like I would expect, but not this 3-gang...
    Am I being too fussy? Is this common?
    I expected the outline around the face of each switch as well as the outline around the buttons on the timer to be flush or proud of the face of the wall plate...
    Oh and for the record, the drywall cutout is not too big, all ears rest on the face of the drywall.
    Plumber jimbo's Avatar
    Fussy? Probably! You should be able to check, before actually installing the timer, how that particular device sits with the faceplate. It may not be designed for the look you are wanting.
    Jun 2007
    North Carolina
    Ditto .
    If the device is too shallow, loosen the screws holding it to the box so the plate scews can pull it forward. You may have to remove the "mouse ears". They could be contacting the back of the plate, preventing the device from "poking" through like the others.
    Mar 2011
    Long Island, NY
    This particular X-10 looking device has no mouse ears, and being it is not a receptacle with plugs being pushed into and pulled out of, loosening those screws a bit may work out fine, as the bezel of this switch assembly seems to be just as deep as the other 2 decora switches. Lets see if JW thinks that would be a code vilation or not. There are even little plastic/rubber spacers made to go behind the switch's mounting plate that slip over the screws going into the box
    Jun 2009
    Canada
    I forgot to mention that I already put little washers made of 14 gauge ground wire behind the timer before I even took the first 3 photos.
    I thought if I made a precise cut (drywall) around the box, and the box was flush with the face of the drywall I wouldn't have problems like this.
    Mar 2011
    Long Island, NY
    C'est la vie mon ami, or as in thse parts, Es la vida, amigo.
    If you just leave it as is, I have a strong feeling you won't even notice or think about it next week
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    leave the timer where it is, and adjust the other two. tighten the switches to the drywall a little more and or loosen up on the trim screws to make them all flush
    Jun 2007
    North Carolina
    Unless the drywall is as straight as glass this is going to happen from time to time. Wrapped studs or uneven mud during the finish can cause things to not be exact.
    What we don’t want to do is start putting things between the devices and wall that might come out causing things to be loose.
    When doing multigrain boxes we can expect then to not be exact for many reasons. The box being slightly out of kilter is another reason that things don’t line up exactly.
    If we use one device made by one manufacturer and another from someone else then this happens.
    Refer to Jimbo’s reply in post #2 for the best answer of this thread.
    throw the round head screws away and use flat head ones. The plate is probably hitting the screws rather than the device.
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Gotta play around with the screws to the box. While the ears hit the wall, it creates tension - which affects how the body of the receptacle/switch sits. -- WHICH is also relative to playing around with how tight you are on the wallplate as well as how flat the wall is. The 3 combo affects it all.....
    The body style while is a *decora* style, the thinkness, etc is different itself....
    So either let it disappear over time as you forget, as the reveals will never be perfectly the same across all three...and a 3 gang pronounces that even more
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    We could call that solution #1, and I like it.
    Solution #2 is to find a different timer that sticks out a little more....
    Solution #3 is to absolutely get over it. I see enormous utility in that approach.
    Jun 2009
    Canada
    Sorry, I was only looking for answers from electricians.
    Jan 2012
    Los Angeles, CA USA
    OK.
    This electrician thinks that the equipment that you have there is not going to give you the result you want.
    Unless perhaps much more discrete screwheads on the timer allow it to get closer to the faceplate.
    I have a dial caliper. I could measure how much the switches extend from their yolk, likewise the timer.
    Or you could just take all three out, have no screws at all at the yolks, and use the face plate screws to determine that you have the devices fully up against the faceplate.
    If you did and the three still looked the same, you would know that you are up against it.
    You did ask if you were being finicky. I think you are getting very close to finicky. Possibly getting over it would be the path of wisdom.
    Mar 2011
    Long Island, NY
    And you actually got answers from 3 believe it or not, and all three think you are being just a little too fussy here. Your post is more about aesthetics than electrical circuits or code, or how things work.
    I took a look at my 3 gang Decora setup, and its kind of like your situation, but it did not bother me or more importantly, my wife, who IS very fussy.
  1. Adjusting wall plates - Moving switches & receptacle outward so wall plate looks good
    By jamminjoe in forum Electrical Forum discussion & Blog
    Last Post: 12-29-2009, 06:21 AM
  2. Customizable Decora Switches
    By TomMar in forum Electrical Forum discussion & Blog
    Last Post: 08-27-2009, 04:48 PM
  3. Wall mounted lavatory faucest-good,bad,ugly?
    By lhparker in forum Remodel Forum & Blog
    Last Post: 05-14-2009, 09:30 AM
  4. are there any good back outlet toilets that aren't wall mounted?
    By craigree in forum Toilet Forum discussions
    Last Post: 11-12-2008, 08:00 PM
  5. Wall hung Daravit Darling is it any good
    By roots in forum Toilet Forum discussions
    Last Post: 02-22-2006, 12:53 PM
