Results 1 to 12 of 12
Thread: Delta tub and shower facet installed..little drip
Hybrid View
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    Default Delta tub and shower facet installed..little drip
    Hey all,
    I just installed the Delta tub and shower kit for my bathroom. It was pretty simple except for the tub spout. Took me a while but figured it out.
    Now here's the problem. When I turn off the water, there's still a drip of water that comes out of the spout. I would say a drip every 2 seconds. I made sure all the connections were tight and everything was done correctly.
    Any suggestions on what to look for?
    If you have a tub/shower valve and run the shower head, it will take 35 minutes for it to drain down completely.
    Jul 2009
    North Vancouver, BC
    On a tub filler last month there was a packing washer that was installed and not needed. It prevented the divertor from fully sitting down and we need to remove it. Once that happen the drip stopped. The drip was with the hand held sprayer and not the tub spout.
    Perhaps check that nothing is blocking the divertor from working properly.
    "When it's Perfect. It's good Enough." - John Whipple ...................... Q: Who are the Top Ten Bathroom Designers for 2010-2012..? ANSWER
    Contact Info: Email jfrwhipple@gmail.com Phone: 604 506 6792 Alternate Email: info@byanydesign.com
    The key to whether it is drain down or a leak is whether it eventually stops. I time the interval between the "drips" and if it does not stay constant, then it is drain down.
    Jul 2009
    North Vancouver, BC
    HJ what if the drips are at regular intervals?
    JW
    If it continues and it's regular, then there is a sealing problem.
    It does take about 35 minutes to quit dripping on a working system.
  1. Toto Soiree Toilet: Drip, Drip, Drip?
    By Philip in Connecticut in forum Toilet Forum discussions
    Last Post: 12-01-2009, 06:20 PM
  2. sputtering and spitting facet and shower?
    By reeveb in forum Shower & bathtub Forum & Blog
    Last Post: 07-05-2007, 01:41 PM
  3. Drip, Drip, Drip from my shower head
    By miranda12 in forum Shower & bathtub Forum & Blog
    Last Post: 10-17-2006, 01:49 PM
  4. drain flange--drip,drip,drip
    By rockjet in forum Plumbing Forum Discussion & Blog
    Last Post: 10-06-2006, 03:39 PM
  5. Shower head goes Gulp Drip Gulp Drip
    By Lakee911 in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2005, 04:43 PM
