Results 1 to 7 of 7
Thread: Help with setup of Discharge side of Goulds sprinkler pump please
    DIY Junior Member markymark423's Avatar
    Jun 2012
    indiana
    Default Help with setup of Discharge side of Goulds sprinkler pump please
    I am in the process of setting up a sprinkler pump for my lawn watering. The pump is a Goulds GT15 with 1.5" suction and 1.5" discharge. I am pretty sure I have the suction side good to go, but I am racking my head trying to figure out the best way to do the discharge side. I want 4 hose bibs that will just run above ground hoses and sprinklers. I was thinking of doing a PVC setup for the discharge, but I am not sure how to go from PVC to a metal hose bib properly. Any and all suggestions welcome. Thanks!
    Moderator valveman's Avatar
    Mar 2006
    Just glue on a female adapter and screw in a hose bib.
    Jun 2012
    indiana
    I thought you weren't suppose to screw a metal piece into a female plastic piece.
    DIY Member tvl's Avatar
    Jul 2006
    South Carolina
    Folks do it all the time, but you do have other options if you like:
    http://www.castlewholesalers.com/MUE...c-3-4-IPS.html
    hope this helps!
    Mar 2006
    Quote Originally Posted by markymark423 View Post
    Maybe down in a well, but it won't hurt anything there.
    Jun 2012
    indiana
    Ok.... Should I use thread tape or thread sealant?
    Mar 2006
    I use both. Teflon sealent over Teflon tape.
  1. Replies: 1
    Last Post: 11-14-2011, 03:07 PM
  2. goulds pump
    By marquezrf in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-13-2011, 05:52 AM
  3. Side Discharge Bath Drain
    By Viking in forum Plumbing Forum Discussion & Blog
    Last Post: 02-22-2011, 05:20 AM
  4. Replacing a Goulds J10S 1 hp pump for home sprinkler system
    By drainfly in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2010, 07:21 PM
  5. Replacing a Goulds J10S 1 hp pump for home sprinkler system
    By drainfly in forum Irrigation / Sprinkler Forum
    Last Post: 07-06-2010, 07:19 AM
