Results 1 to 2 of 2
Thread: Lavatory Drain
    DIY Junior Member Book3's Avatar
    Jan 2009
    Pittsburgh, Pa.
    Default Lavatory Drain
    I am helping my son in law install a bathroom in his basement that was plumbed with drain and water lines when the house was built 2 years ago. The toilet and tub were no problem. Where I do have a problem is with the drain for the lavatory. The floor drain is centered between the water lines. Because they went with a 48" lavatory, it puts the center of the lavatory drain about 18" from the floor drain pipe. What is the correct way to deal with this? Do I put the trap directly under the lavatory drain then run a horizontal pipe over to the floor drain and elbow it down at that point, or do I com down from the lavatory draw, install an elbow and run horizontally over to a trap and striaght down to the floor drain? Any help would be appreciated.
    Jerry
    Actually NEITHER, without a vent the drain will NEVER operate properly. Whoever installed the drain, (and, the trap should be under the sink, NOT be under the floor), should have put it in the wall with a vent going upward, OR it was installed that way, but you moved the wall so the pipes are under the sink and could not continue the vent the way it was designed.
  1. lavatory drain question
    By thezster1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2010, 06:49 PM
  2. lavatory drain alternative to pop-up
    By joni41 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2009, 03:12 PM
  3. Lavatory pop up drain
    By pbr3232 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-25-2009, 08:30 PM
  4. lavatory drain: need suggestions
    By traff_ss in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-24-2007, 03:13 PM
  5. Lavatory Drain NOT Draining
    By Redrobster in forum Shower & bathtub Forum & Blog
    Last Post: 12-24-2005, 06:50 PM
