Results 1 to 5 of 5
Thread: Dirty Water
    DIY Junior Member Jendo's Avatar
    Jun 2012
    Eastern NC
    Default Dirty Water
    This is my first post, hope someone here can help/advise me.
    I'm a homeowner with a backyard well intended originally for lawn irrigation. Problem was that the electric pump kept burning out. I recently replaced it (electric pump) with a hand pump. Intention is to simply use well now for an emergency water supply on the property. 1st week, the water was sparkling, clear, odorless, effervescent even.
    I planned to get the water tested, but dropped the ball for a couple of months. Just ordered a test kit, went out to collect a sample and got nasty green smelly water. pumped for an hour and got brown silty water. This water gets much more clear with 24 hours standing, but still does not appear appetizing. Sediment is very fine particulate, I'd guess something like brown baby powder texture. I have not felt of the sediment.
    Was advised to pour several gallons of Clorox into the well. Seemed like a lot to me, so I did .75 gallons, 2 times, several days apart. Pumped a lot of water after letting it sit for several days.
    The well is small diameter, not sure, maybe 1"? Approximately 25' deep.
    I will say, it helped a bit with the odor, but the color and turbidity is even worse now.
    I am in Eastern NC, small town. There has been no ground disturbance, as far as I know.
    Any ideas what could have happened to my nice water?
    Suggestions on what to do?
    I don't see any point in testing such foul water.
    Thanks for any help.
    Moderator valveman's Avatar
    Mar 2006
    You probably have a problem with the screen on your well point. You may need to drive a new one.
    Jun 2012
    Eastern NC
    Thank you for your help.
    Do you mean drive a new well, or just have a new point/screen installed?
    I looked at information/diagrams on the web. My galvanized pipe is just coming out of the earth, with no concrete base around it. I wonder if water is leaking down the pipe and contributing to the problem?
    I am guessing that wells intended for other than irrigation should be quite a bit deeper?
    Mar 2006
    If you can pull the old point, you can replace it with a new one. If not, just move over and drive the new point. Irrigation or not, you only go as deep as there is water.
    Jun 2012
    Eastern NC
    Thank you.
  1. Dirty water
    By wlwdaw in forum Plumbing Forum Discussion & Blog
    Last Post: 10-22-2011, 06:04 AM
  2. Dirty water
    By mlm in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-08-2011, 08:54 AM
  3. New Well....Dirty Water Help?
    By lovey55 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2010, 06:24 PM
  4. Dirty Water
    By KevinH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-05-2009, 08:43 PM
  5. dirty water
    By jon61 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-13-2005, 06:29 PM
