Results 1 to 6 of 6
Thread: 2 inch deep jet well single pipe help
    DIY Junior Member Jerred18's Avatar
    May 2012
    NC
    Default 2 inch deep jet well single pipe help
    Can I use 11/4" beveled pipe in a 2" casing. The od is 1 7/8" on the suction. Is the 1/8" clearance enough to feed water back to the ejector? Thanks
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Is this steel casing or pvc? It's not the pipe that causes clearance issues, it's the couplings. All 2" wells with packers are designed to be used with 1.25" pipe. You have to have special thin collars to go into the 2".
    May 2012
    NC
    It is a steel casing. I bought 1 1/4 inch belled 20ft sections. The widest part of the belled end measured 1 7/8, that only give 1/8 clearence for water to go back to the ejector. Will this work?
    Feb 2010
    SE Texas-Coastal
    How are you going to connect to the jet and well head?
    Well head part should be easy-thread the 1.25" pipe and just screw it on.
    I would not use PVC pipe in a steel 2" well with a packer jet.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    On a 2 inch or smaller casing you can connect the pump suction pipe directly to the well casing.
    http://www.deh.enr.state.nc.us/osww_...AL_Sep2009.pdf
    Moderator valveman's Avatar
    Mar 2006
    Quote Originally Posted by Smooky View Post
    You need the two pipe jet if the water level is deeper than 24'.
  1. 2 inch deep well jet
    By hickster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-31-2009, 05:10 PM
  2. broken pipe in deep well?
    By Jasonx040 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2009, 02:40 PM
  3. Help! I need a Deep,Large Single Basin Sink
    By cfrussin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2007, 07:07 AM
  4. 2 inch single pipe packer diagram
    By sucker dave in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-11-2006, 02:55 PM
  5. Cutting 2 inch and 3 inch copper pipe
    By JohnO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2006, 10:35 AM
