Originally Posted by
F6Hawk
The gas tank analogy kind of works, LS... the tank's capacity is 20 gallons, you use 3/4 of it, or 15 gallons, and it will take 15 gallons to refill it. The last 5 were still there, if needed (kind of like a reserve), so they don't need to be replaced. (nvm if you have an innacurate gauge or other anamoly, we are talking capacity of the tank).
For resin, if the capacity is 20K (1 cu ft @ 6 lbs salt), you use 3/4 of it, or 15,000 grains, and it will take enough salt to replenish the usage, with about 5,000 grains remaining in the resin which was not used. Provided you oversaturate with enough salt to replenish those used 15K grains, you now have a max capacity of 20K again. Now, it stands to reason that not 100% of the media will take on sodium, and therefore the next time, you may not have exactly 20K of capacity... but for all practical purposes, your water will be soft, and the little hardness that snuck by will go undetected. (Unless you are testing with something more precise than the Hach 5B)
At least, that's how I understand it. Feel free to shoot down my theory, oh ye gods of sodium-enhanced water!
