Results 1 to 9 of 9
Thread: Connecting 1/2" copper to old 3/4" brass pipe
Hybrid View
    DIY Junior Member sean farrell's Avatar
    Jun 2012
    Boston
    Default Connecting 1/2" copper to old 3/4" brass pipe
    Hello,
    I am doing my bathroom over. There is still some old pipe in the walls that looks to be 3/4" threaded brass. In some places the 3/4" brass has been connected to copper. It looks like the 1/2" copper was just inserted into the cut 3/4" brass and then soldered.
    I have to do something similar and I am wondering if this is the correct approach. If yes, is there any trick to doing it? If no, what is the correct way?
    Sean
    IF your description is correct and it is really brass pipe, then the proper connection is to thread it and use copper to IPS adapters.
    Jun 2012
    Boston
    Thanks HJ, I am pretty sure it is brass based on the fact that if I scrape away at it the metal is yellow and the age of the house (about 80 years).
    I don't have the kit to cut threads and would like to avoid buying it for two joins. I do have access to existing joins (elbow fittings). What are my chances of unscrewing the pipe at these joins and ending up with clean reusable threads that I can then attach the IPS adapters to? I have heard that old brass is brittle to work with. Can I muscle it and expect good results?
    Thanks.
    Old brass is seldom "brittle" and almost always unscrews fairly easily.
    Jun 2012
    Boston
    Hello HJ, I'm not familiar with plumbing terminology. Does IPS mean Iron Pipe Standard, in which case are these the standard sized couplings I can get at the big box stores. I have purchased a 1/2" NIBCO coupling, with a 1/2 female one side and threaded on the other. The threaded side looks about the right side but just wanted to check this is what you meant before cross threading it or something.
    Sean
    IPS is "iron pipe size" which is the ONLY size you will find at hardware and plumbing stores. Couplings should be threaded female pipe on BOTH sides.
  1. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2013, 09:34 PM
  2. "play" in copper pipe
    By rmc115 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2012, 08:37 PM
  3. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2011, 04:51 PM
  4. Brass pipe has same OD as 1/2"copper coupling
    By PeakXV in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2010, 05:43 PM
  5. How to solder a "T" in copper pipe?
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2008, 05:29 AM
