Now why do you say that? IF my installation is the problem, then let's address that. If what i am trying to do is the problem, then let's address that. I have searched and found other people who would like to be able to control a damper on each line of an exhaust run and the inline fan. If it's my installation, what's the problem? If it's the components, what's the problem.
I would say if it's the components, then by all means, close and delete, as I wouldn't want improper parts being used, but if it's my installation, then I say let's address that, so if anyone else is trying to accomplish this, leave it there for them.
BTW, the picture I posted is obvoiusly a hack of two pictures, so it is kind of a diagram from actual picture. What DonL referred to as uninsulated wire, is just where I didn't color in where the end of the wire will be under a nut. If it's the uninsulated ground, I can redo it so I have full outer sheathing coming to the transformers. Other than that, what is the problem? Do you just want to see the whole board in a box, due to the fact that the wires are not in the romex? If so, can you explain why the little bit of exposed copper at the screw terminals is any different than that amount being exposed in a switch box? Just asking, because this really didn't seem to bad, I was kind of shocked by the doom and gloom, but I want to make sure that is not due to a mistake on my part of representing the installation properly. Anyway, thanks for sticking with me so far (if it lasts)...Daniel
