It is going down to 30 that is your problem. I can't find that pump model number. But I think it will do more pressure than that. I would first just try adjusting the pressure switch. If you can get it to run at 50/70, or even 45/65, the pressure will be much better. Either way you only want 20 PSI between on and off, not 30.
