Results 1 to 7 of 7
Thread: Where to buy flexible plastic tubing?
    DIY Junior Member grizz's Avatar
    Jun 2012
    Colorado
    Default Where to buy flexible plastic tubing?
    I'm currently putting pieces together for my 365ft well and was wondering where you guys buy 1 1/4" plastic tubing. It looks like my local home depot only sells the 1" size roll of plastic tubing but my pump has a 1 1/4" discharge. I've come across a few websites that sell it for an outrageous price, just wondering where the pros buy from. Thanks
    you do realize that there will be about 160 psi static pressure on the pipe where it connects to the pump, I hope. Then add the operating pressure of the system and you have a serious dynamic pressure to contend with, so you need GOOD plastic pipe AND connections.
    Jan 2008
    Any plumbing supply house should have or be able to get it. Make sure the stuff you get is rated for potable water. There is a lot of PE that is not as such.
    You need to look at the head pressure for that depth. Most PE is not recommended for that deep.
    http://www.deanbennett.com/well-accessories-page21.pdf
    Jun 2012
    Colorado
    thanks for the replies! I didn't know about the 160 psi at the pump, is there a formula I can use to figure out what my exact pressure will be? It wont be hooked up to any pressure tank and will only be used to fill a water storage tank once in a while. Thanks for the help guys
    Jan 2008
    Every foot of water in a vertical pipe adds .433 psi. The height of water in a non-pressurized tank can be added the same way.
    Moderator valveman's Avatar
    Mar 2006
    I know the pump has 1 ¼” discharge, but that doesn’t mean you have to use that size pipe. If the pump will produce less than 15 GPM, I would use 1” pipe. It would be less expensive, less weight, has a higher burst strength, and probably easier to find.
    Nov 2010
    Maine
    I hang 90% of residential pumps on 1" - 160lb.
  1. Attaching ferrule to plastic tubing
    By vaman77 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-14-2012, 06:01 PM
  2. Kink in flexible copper tubing underground
    By mdavis130 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-09-2009, 05:31 AM
  3. flexible tubing instead of compression fitting?
    By stamp in forum Shower & bathtub Forum & Blog
    Last Post: 04-22-2008, 06:19 PM
  4. Plastic Tubing Compression Fittings
    By deuce1974 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-05-2007, 08:59 PM
  5. Flexible Copper Tubing
    By Beachcomber in forum Plumbing Forum Discussion & Blog
    Last Post: 12-13-2004, 11:35 AM
