Results 1 to 9 of 9
Thread: Setup for pumping lake water for irrigation
    DIY Junior Member Cabin fever's Avatar
    May 2012
    Texas
    Default Setup for pumping lake water for irrigation
    Hi.
    I have small area by the lake that I would like to grow grass and plant some trees. I plan to use an above ground sprinkler head connected by a garden hose and drip hoses for the trees. Can someone help we how I should set this up? Can I just hook the garden hose to the jet pump. Or should I use a pressure tank?
    Also, how can I incorporate a timer into this setup?
    Thank you in advance for any suggestions.
    DIY Junior Member BrianK's Avatar
    Jun 2012
    Calgary, Alberta, Canada
    I did what you are planning to do. I didn't use a pressure tank and just connected a hose to the pump discharge. I used a 1/3 HP jet pump. I did this because I wanted to use a timer to operate the pump so it only came on for about 1/2 hour every 4 days - automatically. I guess I could have used a pressure tank too but it was simpler to just connect the hose to the pump. I didn't want the pump cycling on/off and wanted the pressure to operate the sprinkers (I usually have 2 or 3 connected).
    I wired up 2 switches to operate the pump - one called Auto; one called On/Off. The On/Off allow me to turn the pump on when I want it on (I generally leave the hose connected to the pump) and in Auto the timer is used to obviously turn the pump on automatically. This is not fancy but works for me. If you just want to do it manually, just plug it in. Works for me as I only wanted to buy the pump and not the pump and tank combo.
    May 2012
    Texas
    BrianK--thank you for the suggestion. Is it ok for the pump to run for 30 minutes straight each time it's on?
    Moderator valveman's Avatar
    Mar 2006
    Pumps are made for continuous duty. They like to run, and it doesn’t hurt if they run 24/7. It is cycling on and off that is bad for them. You can use a timer for the pump if you run everything at the same time. But if you want to be able to turn on a hose or a zone valve and have the pump come on automatically, you need a pressure tank and pressure switch to control the pump, and some way to eliminate cycling.
    May 2012
    Texas
    Thanks Valveman. In that case I will keep things simple by using just the pump with a timer, no pressure tank.
    DIY Junior Member bala's Avatar
    Jul 2012
    Toronto, Ontario
    Hi Valveman,
    I have a similiar situation to what is being discussed here. I have a Grundfos 1/2 HP pump with a 9 gallon Pressure tank that is right by the lake. I have attached a picture as I think that the water should be going to the PT first and not out to the hose. It seems that mine is running all the time too....the white PVC on the right is going to the pressure tank but the first outlet on the left is going to the garden hoses. Should it be the other way around? PT first then hoses?
    Mar 2006
    The picture did not post. Download the picture to this website... http://tinypic.com/
    Then use the link for message boards and forums to post the picture here.
    Jul 2012
    Toronto, Ontario
    If you want to get real simple MELNOR sells a 1 hose timer called AquaTimer. Its 30 bucks at Home Depot and takes 2 AA batteries.. Very easy to water your fav trees.. Basically its a timed valve that you put right on a loaded hose.
  1. lake water supply setup. in Ct lake
    By tooks7 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-07-2012, 12:10 PM
  2. Pumping lake water for irrigation & power washer - set up?
    By chuck b in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-22-2011, 06:21 AM
  3. Method to keep irrigation pipe above lake floor
    By cory2605 in forum Irrigation / Sprinkler Forum
    Last Post: 06-19-2009, 09:16 AM
  4. Pumping Out of Shallow Irrigation Canal Advice
    By 71Ranger in forum Irrigation / Sprinkler Forum
    Last Post: 03-06-2008, 11:37 AM
  5. pressure loss with lake irrigation system
    By tdarr3785 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-20-2008, 06:11 AM
