When system is in use the pump never reaches the cut of pressure of 60 instead it will stay around 55psi (depending on how much water I'm using). Everything else seems to be working grate. Is that because I reached the perfect recovery rate of the pump? It worked fine at 30/50.
Pump - Goulds J7S set at 40/60
Bladder Tank - well-x-trol 44 gallon
Water usage 4 gallons per minute +
well depth 25ft
well depth 25ft
