Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Washer Dryer Hook Up Moving to Upstairs
  1. #16
    DIY Member skoby's Avatar
    Jun 2012
    Massachusetts
    What are the requirements for a laundry sink. There's a 1 1/2" drain pipe on floor below where I'd like to put the washer.
    If 1 1/2" is ok then I could run a pipe one floor down and into a laundry sink. It's not the best solution but may be allowable if the 1 1/2" drain is sufficient.
  2. #17
    A laundry sink is supposed to be 2" waste line and 1.5" trap arm.
    A washer is 2" waste line and 2" trap arm.
    Some areas like a 3" waste line and 2" trap arm for a washer.
  3. #18
    Nov 2010
    Maine
    IPC is now all 3" waste and 2" trap arm.
    If you are in Mass, doing this without a permit and a license could land you in a world of trouble and wind up costing ten times what you saved by doing it yourself. Not that I'm being anti DIY here because I have been accused of that before, just telling you the what if's. Massachusetts is not a DIY plumbing friendly environment.
  4. #19
    Jun 2012
    Massachusetts
    Looks like I'm at a standstill for now.
  5. #20
    Jun 2012
    Massachusetts
    I haven't done anything yet except pull down walls. I'm still deciding if it'll be worth it to have it done.
  6. #21
    Short answer...if the pipe exits out the roof, it is likely a vent! Now, you don't need a bunch of vents out the roof, they can be combined, but the rules are you can't combine them just anywhere...it must be 42" above the highest drain or 6" above the flood plane of the sink, whichever is higher. Once a drain, always a drain...same thing on a vent. Now, sometimes it isn't that hard to add a vent so you can use an old one for a drain, but again, there are rules.
  1. Broken dryer on washer dryer combo
    By Kristoffer in forum Electrical Forum discussion & Blog
    Last Post: 12-14-2011, 11:37 AM
  2. Moving washer and dryer to basement
    By tmjacobs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2011, 05:56 AM
  3. Moving washer/dryer from kitchen to basement
    By tedeverson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2009, 06:44 PM
  4. Moving Washer dryer to Upstairs Bath
    By kess22b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2007, 08:51 AM
  5. What’s involved in relocating washer/dryer hook-ups?
    By Wayno1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-13-2005, 04:12 PM
