Results 16 to 30 of 36
Thread: New Project: Water Cannon
  1. #16
    Nov 2009
    VA
    No. Although you could get the voltage with say 20 car batteries (~240v), it would still be DC (direct current) and the pumps that you listed are for AC (alternating current). There are ways to convert DC to AC, but it isn't worth it for something like this. The best thing is to get a pump that is designed for 12v.
    You may have a hard time finding a 12v pump that will do 40-50 gpm, and if you do, it may draw a lot of current and drain the battery quickly. It is worth searching for, though. Depending on what you find, it may be a matter of reducing the nozzle size on the cannon in order to still get the distance, but with less flow.
  2. #17
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    You need a 12 volt DC pump.
    http://www.northerntool.com/shop/too...atchallpartial
    If you need something more powerful than a 12 volt direct current pump then get a gasoline powered pump.
    http://www.northerntool.com/shop/too...8463_200398463
    If that does not work then you could get a gas powered generator that could power the type pump you are trying to use.
  3. #18
    Mar 2011
    Houston, TX
    Sounds like a overkill to have some water fun.
    Walmart sells cheap Water Guns that are fun. Lakes are for swimming, water skying and fishing in the USA.
    Portable batteries that can give 230V are hard to find and would be very expensive if you did find one.
    A gas powered motor driving a pump is the only way to go if you are serious about the flow that you want.
  4. #19
    DIY Junior Member ?ukas H?u?t?ler's Avatar
    Jun 2012
    Germany
    Allright, thanks everybody for your awesome tips. So I found this 12v pump that would do 55 gpm at a 4m head.
    More details:
    95 Watt/8000 U / min
    DC 12 V/13 A
    (http://www.amazon.co.uk/Professional.../dp/B004J0FJZS)
    I found a nozzle that can take it down to 1 cm, do you think it'd work on one or a couple of car batteries? If yes, should I get a tighter pipe (the one I have now is 18 mm) for the cannon to maximise pressure?
    Peace,
    [EDIT] - Forgot to pot an example battery. How's about this? http://www.amazon.co.uk/Alphaline-07...9169224&sr=8-1
  5. #20
    DIY Junior Member chad1988's Avatar
    May 2012
    Kansas
    That sounds cool. I've always wanted to make a water cannon.
    Chad
    My Cover of Wrapped Around Brad Paisley's song.
  6. #21
    Mar 2011
    Houston, TX
    Quote Originally Posted by ?ukas H?u?t?ler View Post
    More details:
    DC 12 V/13 A
    Peace,
    You may have better luck going with a Deep Cycle Battery.
    A Deep Cycle Battery would last longer in that application.
    Have Fun, Be safe and wear Eye protection.
  7. #22
    Apr 2011
    NC
    The pump in your link looks like a bilge pump. With 4 meters of head that converts to about 6 psi. I would think you need more psi to spray farther. I would go with a pump with higher pressure so the cannon will shoot more distance. I would play around with different nozzles to get the distance you want.
    Also the pump in your link is a submergable pump, not sure if that is what you need or not. Where do you plan to locate the cannon and the pump? By where I mean is it going to be on a dock, beach, in a kayak, or mounted on the roof of your car? To get good answers you have to provide good information and a description of what you plan to do , pictures help too.
  8. #23
    Jun 2012
    Germany
    Quote Originally Posted by Smooky View Post
    That's what I was afraid of. I've made a couple different nozzles that work great, one of 7 mm, the smallest one 3 mm. Here's a nice drawing of what I'm planning:
    Name:  Water cannon.jpg
    I could be standing on a small yeti as well, but this is basically the confguration. The idea is to be able to fit the battery into this suitcase:
    It's 13" x 19,5" x 7,5"
    This is the prototype barrel. It's 18 mm Ý, 26" long and can be bushed down to 7 or 3 mm at the end by the nozzles I've made. Water will be fed from the right. Would it maximise pressure if I'd use a hose tighter than the barrel to feed the water through the pipe? Or is it equated when the water is forced down to 3 mm?
    Thanks again you guys for your great help,
    Lukas
  9. #24
    Apr 2011
    NC
    Many of the 12 volt submergible pumps that I am finding pump a large volume of water but do not produce a lot of pressure. There are a few, but they can get rather expensive. Here are some links to 12 volt pumps. Most of this type of pump is used in motor homes or it is the type used for agriculture sprayers. This type of pump does not set in the water. You would need an intake hose that would be placed in the lake. You need a float or something to keep it from sucking up so much trash and a strainer. The suction hose needs to be hard enough so it will not collapse when the pump starts sucking on it. I would use hose and fittings with at least ĺ inch inside diameter until you get to your cannon, otherwise don’t try to restrict the flow except for the nozzle at the end of the cannon. I believe I would just use a battery box and forget the suitcase. You could always camouflage it some other way or let the yeti hold it.
    http://www.all-about-the-home.co.uk/...12v-6843-p.asp
    http://www.amazon.co.uk/dp/B006J7VL8...SIN=B006J7VL8S
    http://www.wcsuk.com/acatalog/SHURFL...4-14-PU48.html
    http://www.williamsonpumps.co.uk/
    http://www.lilie.com/shurflo/infos-2s.pdf
    http://kanubistanker.de/online-shop/...schwasserpumpe
  10. #25
    Jun 2012
    Germany
    Many of the 12 volt submergible pumps that I am finding pump a large volume of water but do not produce a lot of pressure. There are a few, but they can get rather expensive. Here are some links to 12 volt pumps. Most of this type of pump is used in motor homes or it is the type used for agriculture sprayers. This type of pump does not set in the water. You would need an intake hose that would be placed in the lake. You need a float or something to keep it from sucking up so much trash and a strainer. The suction hose needs to be hard enough so it will not collapse when the pump starts sucking on it. I would use hose and fittings with at least ĺ inch inside diameter until you get to your cannon, otherwise donít try to restrict the flow except for the nozzle at the end of the cannon. I believe I would just use a battery box and forget the suitcase. You could always camouflage it some other way or let the yeti hold it.
    Hey thanks for looking these pumps up.
    So I'm looking at this one: http://www.wcsuk.com/acatalog/SHURFL...4-14-PU48.html
    It seems like something I could use, high pressure and all. However, it just pumps 13 liter per minute, 7,8 times the volume of the barrel. Even at high pressure, will this really be enough? Seems to me that the pumps would still need to pump a certain volume to get it right, or am I totally wrong?
  11. #26
    Apr 2011
    NC
    Here are a few links to Flojet pumps. Some of them can pump up to around 5 gallons per minute. If you nozzel down your cannon and use a pump that has at least 30 psi, it should work very well. You should be able to shoot alot over 12 feet, even at 7 mm.You should be able to find this type of pump with 30 to 60 psi. The higher pressure usually the volume will be less. so a pump that has 30-45 psi and around 5 gallons per minute should do very well. Even a 3 gallon per minute should do pretty good.
    http://sports-explorer.shoppingfount...uk/228771.html
    http://sports-explorer.shoppingfount...uk/Flojet.html
    http://www.amazon.co.uk/Flojet-3526-...5&sr=8-2-fkmr1
    http://www.justkampers.com/shop/leis...rs-j16859.html
    http://www.gocaravanning.com/caravan..._batteries.htm
    http://www.amazon.co.uk/Draper-66802...332319&sr=8-63
  12. #27
    Nov 2009
    VA
    You will need more tha 5 gpm unless you go smaller on the nozzle. The volume needs goes as the square of the diameter. For instance, if you took my original calc and used say a 9mm nozzle, the reduction in volume would be (9/18)^2 = 0.25, so about 36 gpm*.25 = 9 gpm (plus additional to cover air resistance).
    With a 7mm nozzle, the required volume is (7/18)^2 * 36 gpm = 5.444 gpm. Again, this is the minimum fllow required to get the distance.
    The design of most things (like this) takes some iteration. In this case, it is like this:
    1. pick a nozzle size (based on what is available or how wet you want to get them)
    2. calulate the volume
    3. calculate the pressure drop
    4. look at pump curves to see if there is a pump available (consider price, power requirements, etc) that can meet the volume minimum at that pressure drop (just looking at max flow or max head won't tell you what you need).
    5. repeat steps 1-4 by adjusting nozzle size until you find something that works.
    Volume is what will determine the distance with a given nozzle size. The pressure drop will be set by the design and the flow rate (friction in the line, losses at the nozzle, etc.). If I have some time later today, I will estimate the pressure drop. Do you know the diameter and length of hose from the pump to the cannon (also type of hose)?
    EDIT: Here is what I came up with. This is the pressure drop for different nozzles at what I calculate for the minimum flow rate. These values assume that the pump is located 2m below the cannon and do not include the losses due to the hose. They do include pressure drop due to elevation change, acceleration, and the losses at the nozzle and at the sharp elbow at the inlet to the cannon. If you keep a small nozzle (and lower flow), the pressure drop is mostly due to elevation. It seems like if you use the 3mm nozzle, you will have the easiest time finding a pump that will work (1+ gpm at say 2.5 m head, higher numbers will work better). If you go to a larger nozzle, the pump will need more flow as well as head.
    Nozzle Size (mm) min flow (gpm) min flow (lpm) dP (m)
    3 1.0 3.8 2.25045
    5 5.4 20.6 2.29762
    7 9.0 34.0 2.56335
    9 16.0 60.5 3.39408
    18 36.0 136.1 7.00267
  13. #28
    Apr 2011
    NC
    Today I got my 12 volt pump out and set it up with an inlet hose in a wash tub full of water. I set the pump on top of the truck so there was about 1.5 meters of lift. I used regular garden hose with a valve on the end of the outlet. I could get from 6 feet to 27 feet by adjusting the valve opening. I did have some collapse on the suction hose but it still worked. My pump has a pressure switch so it turns itself off when it builds up enough pressure when the valve is closed. When I allow it to build pressure and open the valve it gets the most distance. With the valve full open, about 12 mm it gets the shortest distance.
    My pump is a 12 volt FLOJET Model 4300-504
    13 amps
    4.9 GPM / 18.5 LPM
    Press 45 PSI / 3.1 Bar Max
    http://www.pumpagents.com/FlojetPumps/4300-504.html
    I use a 3/4 inch inline filter similar to the one in this link on the inlet side of the pump.
    http://www.bing.com/images/search?q=...=0&FORM=IDFRIR
  14. #29
    Mar 2011
    Houston, TX
    13 amps
    4.9 GPM / 18.5 LPM
    Sounds like fun.
    I guess you could add a small tank using a pump like that so you would have a little reserve.
  15. #30
    Mar 2011
    Long Island, NY
    snipped
    Also, I would think that 230 Volts AC or DC would be very dangerous to use with a water toy.
    I like regular pump up water canons, which do a good job and are cheap enough.
    German and Swiss designers come up with fabulous equipment; I work for a Swiss company, but everything is always overkill, WHY????????????????? Like Don said
  1. Results and video of my first DIY Solar Hot Water Project using 300' coil of Pex
    By TheycallMeDave in forum Solar and Geothermal Water Heating Forum
    Last Post: 08-17-2011, 12:21 AM
  2. PEX, Water service from meter to house, DIY project????
    By KBF in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2009, 10:39 AM
  3. I need help with my still project
    By Hillbilly Man in forum Boiler Forum
    Last Post: 12-01-2008, 03:18 PM
  4. I need help with my still project
    By Hillbilly Man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. anatomy of a project
    By geniescience in forum Remodel Forum & Blog
    Last Post: 06-28-2007, 07:15 PM
