Results 1 to 12 of 12
Thread: What lubricant to use for installing bladder into pressure tank?
    DIY Junior Member Joelk's Avatar
    Apr 2012
    PA
    Default What lubricant to use for installing bladder into pressure tank?
    I have a pressure tank that I was going to use for another project, so I pulled the bladder out. I put dish detergent in the tank to lubricate it and let the bladder to slide out.
    The bladder appears to be in good condition and I would like to put it back into the tank. What lubricant should I use for installing it?
    Thanks, Joel
    Dec 2009
    northfork, california
    1.5 litres of wine or a bottle of whiskey, taken internally. Not a project I do any longer.
    Mar 2011
    Houston, TX
    Water is a lubricant.
    KY is Water soluble.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Jan 2008
    Joel, what they are trying to tell you is that no one bothers replacing tank bladders. When a bladder fails, the pros will always install a new tank. There is a lot less labor involved, and it will have a warranty.
    Apr 2012
    PA
    I realize that it may not be worth the COST to replace the bladder, but all I want to do is put the good one that I took out, back in. The tank/bladder are not very old and seem to be in good condition so I don't want to throw them away.
    I think I can put it back in, in less than 10 minutes using dish detergent as a lubricant, but was thinking there might be a lube that would not need to be rinsed out as extensively as the dish detergent will.
    Would Clorox work well? It would have some lubricant effect and disinfect things in the process, but would it be detrimental to the bladder/tank?
    Mar 2011
    Houston, TX
    Seems to me that Clorox could be caustic if it gets trapped in between the tank and the bladder. If the tank is metal that may not be good.
    I think Ivory dish washing soap would be as safe as anything.
    Apr 2012
    PA
    Thanks for the reply.
    It is a "plastic" tank, and I can use Ivory/Palmolive, but was just wondering if there was something that would be better for the project.
    Mar 2011
    Houston, TX
    Quote Originally Posted by Joelk View Post
    If it was working and is good, I am not sure why you removed it.
    If it is not broke why fix it ?
    After said and done it may not last very long.
    Plastic tanks do not last very long here because most are outdoors and in the sunlight.
    Apr 2012
    PA
    I removed it because I originally planned to us it for something other than a pressure tank.
    I re-installed the bladder this evening. I decided to try installing it without any lubricant so that I would not have flush out the lubricant. It may have been even easier w/lube, but it went in very easily WITHOUT ANY LUBRICANT. It was VERY easy to do and took less than 10 minutes to install.
    From the little research I did, it appears that you can buy a new tank/with bladder for not much more than just a bladder(you can get big discounts on tanks, not so much with bladders), so it is probably not something you would want to pay a professional to do, but if you are a DIYer, and your tank is good, it should take less than 1 hour(perhaps less than 1/2 hour) to remove and replace a bladder once you have the plumbing disconnected.
    Dec 2009
    The impossible ones are the old bottom hole sears type flotec style. Better to wrap on your knees with a hammer than try and fix one of those slime balls. You must have the new fiberglas ones that are designed to actually be replaced.
    Apr 2012
    PA
    It is fiberglass wrapped "plastic" and is fairly new.
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    The fact that it is a replaceable bladder means it will need replacing. It is how the bladder fits in the tank that causes the problem. If the bladder can touch the tank, it will rub a hole in it. Most diaphragms or bladders that cannot be replaced are made in a fashion not able to touch the inside of the tank as they move up and down, and generally last longer.
  1. why is a pressure tank with a bladder better than plain old steel pressure tank
    By fcbclan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-26-2012, 02:56 PM
  2. Pressure Tank Bladder?
    By Doozy8 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-25-2011, 08:05 AM
  3. Pressure tank bladder
    By VA Rigger in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2009, 07:41 AM
  4. Pressure Tank Bladder
    By VA Rigger in forum Plumbing Forum Discussion & Blog
    Last Post: 10-26-2009, 03:35 PM
  5. Installing a bladder tank horizontally?
    By hlbmab in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-17-2006, 02:38 AM
