Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 90
Thread: Replace all Wiring that was Stolen any great suggestion???????????
  1. #16
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Oh, and seeing as how you are into a full rewire, if the basic lighting circuits were wired with 12 ga, definitely do as much of the house in 14 ga as you can, you will be very glad that you did.
  2. #17
    DIY Member Erico's Avatar
    Nov 2007
    NY
    Quote Originally Posted by Homeownerinburb View Post
    Just curious. Why run 14 instead of 12? We were just doing some work on my mother-in-law's and the sparky told me her town is all 12ga./20amp now.
    I was wondering if more jurisdictions was going that route?
  3. #18
    Jul 2005
    Marin Co. Ca.
    As an electrical contractor I would deal with the homeowner’s insurance and everyone else would be left in the dark until after the work was completed.
    In the event of no homeowner’s insurance then the deal would be struck with the financial intuition the owner would be using to pay for the repair.
    At any rate he is looking at a handful of dollars to affect the needed repairs. I am assuming that no one was in the house when this happened therefore the homeowner must be using this as rental property in which case insurance will be involved.
    great advise ! I was thinking insurance also. Can the poster explain how this came to be? Rental? House broken into, or empty?
  4. #19
    Jul 2005
    Marin Co. Ca.
    I also run 12 for it all,except greater than 20 amps. Of course ,My work is repair n remodels, not track housing.
  5. #20
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by Erico View Post
    It is vastly easier to work with. And the lighting and outlet circuits around your house except as required (kitchen, bath, laundry) are all fine at 15 amp.
    I know of no jurisdictions that demand all 20 amp. Which is not to say none exist.
  6. #21
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by toolaholic View Post
    I do almost only repair and remodel. On the occasions that I do a full re-wire to get rid of old rag wire and to improve circuits (in conduit) I do as much as I can in 14 ga. There is a significant price differential as well, to my eye.
    Obviously, if you are extending a circuit, you just match wire gauge to the protection existing.
  7. #22
    Jun 2007
    North Carolina
    There are many misinformed people out there that think a 20 amp circuit is better than a 15 amp circuit for general purpose circuits.
    Let’s look at this from a logical stand point. The cords that come on appliances used on general purpose circuits such as TVs, DVD players, lamps, ect… will be either a 16 or 18 gauge conductor. These cords have an ampacity of 7 and 10 amps respectively.
    Using a 20 amp circuit to supply these appliances will allow at least 600 more watts of heat to travel through these cords in the event of a failure. This heat will most certainly cause more damage to the insulation than a circuit of lesser value.
    Sometimes we think we are doing something that is better when in reality what we are doing is causing more problems. If we look at the owner’s manuals of some of these appliances we will find that plugging them into a 20 amp circuits is beyond the recommendations of the manufacturer.
    What we seem to forget is that the breaker or fuse is there to protect the conductors not the appliance being plugged into the receptacle. Should a 15 amp circuit be overloaded the worst thing that will happen is the overcurrent device open but when we start installing a 20 amp overcurrent device on circuits that have cords that are rated at only 7 to 10 amps then we are causing problems especially if we are using such things as dollar store extension cords or plug strips.
  8. #23
    IF you do NOT "bash" the box out, but rather cut it out, then a "remodel box" should fit the opening and you have enough room to work the wires before installing the new box, meaning that there should be very little drywall repair to do. Connect the ends of all pairs of the cut wires together before going down into the room, then you can test all the wires at one time saving multiple trips into the attic.
  9. #24
    Jan 2012
    Los Angeles, CA USA
    Hmmmm. I like this. It depends a lot on what sort of boxes were used. Metal boxes with screw-down strain reliefs would be less amenable to this approach than plastic.
    I don't know if I would trust remodel boxes with flip out lugs for receptacles, if the hole in the wall has been banged around a bit. If I did install them, and they were going in next to a stud, I'd think about drilling a couple of small holes and running some screws into the stud, if that would not cant the box around.
    Anyway you count it, the OP has a mess on his hands, and would be well advised to have a relatively competent assistant on hand.
    Hell, my daughter at age 6 helped me pull #2 thru some conduit that passed under a walkway between the house and garage. Ten years later she is almost less useful....
  10. #25
    Jan 2012
    Los Angeles, CA USA
    Good points, frankly was not at the front of my mind.
    For me the fact that is lots easier to work with 14ga and it demands less space in boxes and that it costs less motivates me to use it as much as I can.
    Just like I try to use the smallest legitimate wire nut, in order to fill the boxes less.
  11. #26
    Jul 2005
    Marin Co. Ca.
    Same 18 Ga. cord can be plugged into a 20 amp plug ! My logical stand point.
  12. #27
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    "If we look at the owner’s manuals of some of these appliances we will find that plugging them into a 20 amp circuits is beyond the recommendations of the manufacturer."
    the appliance does not care what is it plugged into, as long as the prongs fit.. as you stated, the OCP for the wire in the wall is the 20a breaker at the panel. as for the 18 ga cord, that is up to the appliance to be fused. 20a vs 15a, it's still going to blow that fuse in the radio/tv/whatever. i guess i don't see your point. if 12 ga was 'incorrect' to use, it would not be able to be used for such a purpose, don't you think? our current house is wired the same way ( i didn't wire it, bought it like that in 2005, new build) and have had zero issues, except from where the 'rockers' got carried away with a rotozip and hit a wire i had to fix.
    i just rewired my rental house. i used 12 ga in most receps, and 14ga for all lighting, outlets separate from lighting. if you are wiring a living room with 10 receps, with your tv/stereo, table lights, etc and then run a something like a vacuum, it gives you what, 600 more watts to play with? yeah, i'll take that, rather than string another dedicated line for a living room circuit.
  13. #28
    Jan 2012
    Los Angeles, CA USA
    [QUOTE=Cif you are wiring a living room with 10 receps, with your tv/stereo, table lights, etc and then run a something like a vacuum, it gives you what, 600 more watts to play with? yeah, i'll take that, rather than string another dedicated line for a living room circuit.[/QUOTE]
    Holy crap! Ten receptacles in one living room? You have the Queen of England as a client?
    It is a large living room indeed that needs more than six receptacles by code.
    I suppose you could be running your monster stereo at full whack so that you can hear it over the vacuum cleaner and then somehow, with a massive flat screen in the room running a vampire load, and then trip the breaker.
    That is one huge living room.
  14. #29
    Jul 2005
    Marin Co. Ca.
    Well said, On My using 12 Ga. in remodeling came from a retired Master Elec. in S.F.He was a German that polished the Ice Cubes ! Nuts on .
  15. #30
    I work with mostly fiberglass boxes. The easiest thing to do is bash the fiberglass box apart and pull the remaining nails. If your dealing with plastic big box store quality boxes its easier to use a sawz-all and carefully cut the nails and then pull the box. Also they make old work boxes that can be screwed to a stud from inside the box so you don't have to rely on the tabs. They are a bit more expensive but worth it if you are up against a stud.
    -rick
  1. $5800.00 to replace the well pump and wiring
    By Jonnie Claeys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2012, 10:18 PM
  2. Pump and Tank stolen
    By dcorazal in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2011, 04:49 PM
  3. trying to find a well pump to replace the one that was stolen
    By dssgateway in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2010, 09:40 AM
  4. What if a good deal might turn out to be stolen?
    By leejosepho in forum HVAC Heating & Cooling
    Last Post: 11-16-2007, 02:12 PM
  5. shower suggestion
    By scottyt in forum Shower & bathtub Forum & Blog
    Last Post: 07-21-2005, 05:32 PM
