Results 1 to 7 of 7
Thread: In-wall vent for waterfall drain?? Air Admittance Valve or cheater vent
    DIY Junior Member conroyt's Avatar
    May 2012
    New Mexico
    Default In-wall vent for waterfall drain?? Air Admittance Valve or cheater vent
    I just had the great idea to install a waterfall in my upstairs interior wall. The pump and drain are located 1-floor below in the basement utility room.
    I've been having problems with siphoning of the upstairs waterfall drain. Sometimes the drain backs up and overflows (BIG problem), and upon waterfall start-up it will sometimes not start flowing until it gives a great big burp.
    My local plumber (great guy!) who installed the unit per manufacturers instructions tells me I need a vent near the upstairs drain. To make a long story short, the only place to vent the drain will be inside the interior wall. He suggests using a mobile-home type vent. The water being vented is always clean and will not emit noxious gases. I am slightly concerned about the potential for mold, so am thinking of putting a screen/air-vent type cover in the wall over the vent to allow for air circulation. I live in arid New Mexico.
    Is this a terrible idea or an acceptable solution? Thanks for your expertise.
    Any AAV needs access to air. Whenever an AAV is installed in a wall, it needs a grill that allows air.
    That would be a good fix for your problem.
    This is a good lesson for all. You can't run a fixture from the top floor and try to "trap" on the floor below.
    The draining water develops so much speed, that it siphons the trap dry. Or installing a trap without a vent also will siphon. Plumbing 101
    Oatey Sure-Vent Wall Box
    May 2012
    New Mexico
    Terry,
    Thanks for the fast response. Is there any difference between an AAV and a "cheater vent"?
    Cheater Vent.
    Who makes something called a Cheater? I would love to see someone try to market that name.
    AAV stands for Air Admittance Valve. That's the term that the plumbing industry uses.
    Has anyone ever seen something marketed as a "cheater vent"?
    May 2012
    New Mexico
    I think I'm answering my own question. Looks like cheater vents are just certified for mobile homes, not site built homes.
    http://www.google.com/imgres?imgurl=...9QEwAA&dur=504
    http://www.muskokahomeinspection.ca/...skoka-Midland+
    That thing that Home Depot sells isn't a legal vent.
    But then a lot of what Home Depot sells won't pass a plumbing inspection. It drives the inspectors nuts, having the tell the homeowner that they installed the wrong parts.
    NOT LEGAL
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    "That thing that Home Depot sells isn't a legal vent. "
    but it is actually labeled as a cheater vent, lol. now that's funny
  1. Can you tie lav drain into a toilet vent (wet vent)? W/SKETCH
    By kmuddzy in forum Plumbing Forum Discussion & Blog
    Last Post: 01-27-2012, 10:15 AM
  2. In-Line Vent vs. Air Admittance Valve?
    By dzd9fy in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2010, 01:15 PM
  3. in-wall drain vent allowing septic smell to seep in?
    By acthungpv in forum Plumbing Forum Discussion & Blog
    Last Post: 10-26-2008, 07:35 PM
  4. Dishwasher drain air-gap -- cheater vent?
    By gardner in forum Plumbing Forum Discussion & Blog
    Last Post: 04-08-2007, 06:36 PM
  5. Can I vent New bathroom vent into dryer vent line?
    By cwolters in forum Shower & bathtub Forum & Blog
    Last Post: 04-25-2005, 04:03 PM
