Results 1 to 2 of 2
Thread: Sprinkler System doesn't Power ON
    DIY Junior Member ua's Avatar
    May 2010
    Ontario
    Default Sprinkler System doesn't Power ON
    Hi,
    I have a hunter sprinkler system.
    It got winterized by someone last year but now when I am trying to start it up, I see no power supply on the controller.
    Power points are working fine.
    Any idea what could be wrong (any cable people usually disconnect while winterization???)
    Cheers!!!
    UA
    Mar 2011
    Long Island, NY
    Quote Originally Posted by ua View Post
    Hi,
    Cheers!!!
    UA
    Power points working fine, meaning what? that the transformer is plugged into a working AC outlet? If you measured the transformers 24VAC output to be OK, have you checked for a blown fuse in the controller. When you say ypu see no power supply on the controller, do you mean that the display panel, if it has one, is dark? I would think that no cables from the controller to the zone valves would be connected, but it is possible that the guy that winterized it may have unplugged the transformer?
  1. DIY Sprinkler System
    By kimbhoot in forum Irrigation / Sprinkler Forum
    Last Post: 04-24-2012, 09:07 PM
  2. New to sprinkler system
    By swift_3 in forum Irrigation / Sprinkler Forum
    Last Post: 05-27-2009, 10:14 AM
  3. What is this on my sprinkler system.
    By rockycmt in forum Irrigation / Sprinkler Forum
    Last Post: 05-10-2008, 11:43 AM
  4. Sprinkler System
    By statjunk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2007, 09:52 AM
  5. Well for Sprinkler System
    By handyman923 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-18-2006, 07:05 AM
