Thread: Humming Sound from Boiler Electrical Component
    DIY Junior Member GregoryR's Avatar
    Jul 2011
    Maine, USA
    Default Humming Sound from Boiler Electrical Component
    Hello,
    As far as I can remember, this piece has been the cause of a humming noise. Any ideas on what this does and if I could easily replace it?
    GregoryName:  IMG_20120529_211511.jpg
    Plumber jimbo's Avatar
    It is the transformer for the low voltage controls. Need to find the specs, might be printed on the other side somewhere. Most likely, it is 24 VAC output rated 40 volt/amps. Any electric supply or heating supplier will have it. Do not subsitute a "doorbell " transformer from the hardware store.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    All transformers make that humming noise. A new one is not guaranteed to be any quieter.
    Mar 2011
    Houston, TX
    Quote Originally Posted by ActionDave View Post
    Especial when mounted on a plate like that.
    Normal operation for the way it is installed, I think.
  1. Electrical Boiler
    By technogirl74 in forum Electrical Forum discussion & Blog
    Last Post: 01-31-2012, 04:47 AM
  2. Bit of an electrical Gremlin on an older boiler system.
    By Doherty Plumbing in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2010, 09:42 PM
  3. Brand New Boiler Circ. Pump w High Pitch Sound
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2009, 05:36 PM
  4. Softener Component Spec
    By RickwSilentp in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-29-2009, 11:10 AM
  5. Component wiring
    By Bevo in forum Electrical Forum discussion & Blog
    Last Post: 12-13-2008, 11:11 AM
