Results 1 to 2 of 2
Thread: Clack Retention Tank Problem
    DIY Junior Member asmart82's Avatar
    Jan 2011
    East Orlando FL
    Default Clack Retention Tank Problem
    The inlet port on my retention tank is causing my plastic c-clip to come off when I screw in the pipe connection, thus allowing water to spray back out. Anyone ever have the issue and/or know what might cause it? The pipe connection screws in fine on the outlet side.
    Nov 2010
    Maine
    Does your tank have the by-pass valves or plain adapters? At any rate you may want to try screwing the pipe into the adapter and then install the adapter and c clip. If that don't work then something is f'd up (technical term) and you probably need to replace the inlet adapter assembly. And remember, it's plastic so don't gorilla the fittings in
  1. Automated Pure Water 12"x60" Retention Tank - Good stuff or BS?
    By Muff in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-29-2012, 07:09 AM
  2. epoxy retention tank
    By ugabulldog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-18-2011, 07:36 PM
  3. Clack WS1 salty water problem
    By 777 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-06-2009, 09:38 AM
  4. Clack WS-1 backwash problem
    By BRob in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-30-2009, 09:29 PM
  5. Well Retention Tank questions (PICS included)
    By mrmichaeljmoore in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2009, 04:07 PM
