Results 1 to 7 of 7
Thread: new toilet install on concrete. Must be screwed down or not?
    DIY Junior Member M_south's Avatar
    May 2012
    Duvall, WA
    Default new toilet install on concrete. Must be screwed down or not?
    Several days ago our contractor re-installed the drain for a toilet. The first install was in the wrong place so the toilet drain had to be moved 6 inches further from the wall. The contractor cut the cement and added new. It seemed to setup fine. This week we've gotten to the DIY part of the project where we install the toilet. We purchased a standard round flange and pipe connector. the flange has 4 screw holes. We purchased cement screws and attempted to screw the flange in to the floor. The screws don't hold. They immediately unseat. The holes are just outside the pipe and the pipe is wrapped in foam. The area where the screws are installed is not stable enough to screw into with out crumbling.
    The floor contractor says that the toilets installed on cement floors don't get screwed into the floor. that the pipe (of the pipe and flange apparatus) is too long and needs to be trimmed. No screws need to be used.
    Fact or Fiction?
    Aug 2009
    South*East
    Unless it's cast iron pipe with a cast iron flange it needs to be screwed down.
    john
    You may need to go to a hardware store and pick up one of the repair rings to hold the "closet bolts".
    They allow for drilling farther out.
    I have NEVER screwed a flange to a concrete floor, regardless of the pipe's material, as long as the bedding material under the concrete is packed tightly around the pipe.
    Aug 2009
    South*East
    The main reason PVC flanges fail it because there not fastened to the floor. If there screwed down it gives more support to the flange preventing it from breaking were the closet bolts come through it.
    John
    May 2012
    Duvall, WA
    Thanks guys,
    Terry do you know where to buy one like this? the flanges sold by my local true value and home depot don't have those extra wide screw holes like the one you picture.
    The flat repair ring pictured is normally at Lowes or Home Depot.
    It's what we carry on the vans.
    I don't buy them there, they cost twice as much at the hardware stores than where I pick up my supplies. That's the beauty of being in construction.
  1. Did I get screwed on my new well?
    By krosspen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-06-2010, 08:49 AM
  2. Screwed up, now I need to know how bad?
    By Rlogic in forum Plumbing Forum Discussion & Blog
    Last Post: 04-24-2009, 06:44 AM
  3. Concrete around ptrap to complete tub install
    By plex4r in forum Shower & bathtub Forum & Blog
    Last Post: 05-28-2008, 05:04 PM
  4. Need advice on how to properly install floor drain in concrete slab!
    By Chris Tittle in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2006, 09:09 PM
  5. How to install offset flange for cast iron pipe set in concrete slab
    By contessa301 in forum Toilet Forum discussions
    Last Post: 01-19-2006, 05:57 AM
