Jwhitman
Just install a pedestal sink. The plumbing can't be moved and the drain is not aligned properly. I bought a PVC flex extension and it leaks. I need about a 2" offset in order to work. The wall pipe comes out and just hits the edge of the pedestal, the j pipe connects, but the pivot action will not reach into the pedestal and up to the drain. I believe a 2"offset will work, but it needs to be 5-6 inches long. I found offset 17" long. Are there any specialty shops that make them and what are the fitting ends on drain pipe called. Does pex come in drain pipe. Any help appreciated.
Thanks for any advice,
J
J
