Results 1 to 2 of 2
Thread: Help!!! Pump keeps running and won't stop!!!
    DIY Junior Member Kevin Bradford's Avatar
    May 2012
    Tennessee
    Default Help!!! Pump keeps running and won't stop!!!
    I am a newbie here and do not have any experience with this sort of thing so please be gentle.
    I have a WaterAce pump, what appears to be a jet pump. Not really sure because I am not very familiar with these things and I can't get the model number. It pulls water from a spring box up to the home. I have noticed that the pump runs for a few seconds and shuts off for about 30-40 seconds then comes back on and runs for another second or two. I have checked to see if anything is leaking or running in the home and there is not. This morning I went under the house to check and found that the pump itself is leaking from somewhere at the top of the tank between what I can tell is the pump and motor. Is there anyway that this can be repaired or do I need to replace the pump? If it can be repaired, what exactly could the problem be? Any help would be appreciated, thanks.
    Moderator valveman's Avatar
    Mar 2006
    Leaking between the pump and motor is the seal. It can be repaired with a new seal, but you have to take the impeller off to get to it.
  1. Stop running water?
    By masato in forum Toilet Forum discussions
    Last Post: 01-28-2009, 06:30 AM
  2. Back-up Sump Pump won't stop running
    By binsky728 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-14-2008, 08:47 AM
  3. Well pump wont stop running with low PSI.
    By Rod M1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-11-2007, 06:17 PM
  4. Pump won't stop running
    By emuis in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-05-2007, 07:39 PM
  5. Sump pump wonít stop running
    By Chewy55 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-20-2007, 09:39 AM
