Results 1 to 6 of 6
Thread: oh-oh - submersible pump wiring -
    DIY Junior Member donberry's Avatar
    May 2012
    South Carolina
    Default oh-oh - submersible pump wiring -
    I messed up. Was getting new siding on my garage and I disconnected the wiring to my well. Contractor turned out to be really messed up and a few months later the siding is still not up and I fired the contractor. Wanting to hook my well back up since we are in the high 90's and my yard is screaming for water, it turns out I did not mark the wires as well as I should have as I did not think it would be months later when i was hooking it back up.
    The system is a submersible pump, a pressure tank with a pressure switch and a control box. I marked the wires going from the pressure switch to the control box and the fuse box, but did not mark the wires coming from the pump as the wiring was lying outside.
    The problem - when they installed the submersible pump, they used 12 gauge wire but it is not color coded, so I have no idea what wire is what. Coming out of the pump are 3 wires but they are all the same color - is there anyway possible to determine what wire is what without pulling the pump. I am told the pump is submerged about 140 feet and I really hate to pull the pump to figure out what wire is what. I am taking for granted if I wire it wrong the pump will run backwaerds ? maybe shortening the life span ?
    ANY help is deeply appreciated.
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    Quote Originally Posted by donberry View Post
    ... is there any way possible to determine what wire is what without pulling the pump.
    I know what I would do to try to sort that out, but I would still confirm things with an experienced installer before actually making any connections. So, I would suggest you call one from the very beginning.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    You can figure it out with an ohm meter on Rx1.
    DIY Junior Member BrianK's Avatar
    Jun 2012
    Calgary, Alberta, Canada
    Hi Valveman
    Would you please elaborate on what to look for between the 3 wires - ie how many ohms between each wire. There are 2 possibilities - If the original installer did not run a ground (as in my case) 1) the 3rd wire could be the cap start line or 2) it could be a ground line. Ohm details for what to expect between each line would be handy to help trouble shoot and determine what line is what.
    Mar 2006
    Lubbock, Texas
    When checking resistance between the wires of a single phase motor on Rx1, the two lowest readings should add up to the highest reading. Example 1,2, and 3 ohms. And if I remember correctly the lowest reading is between the yellow and black, the middle reading is between the red and yellow, and the highest reading is between the black and red.
    Jun 2012
    Hi Valveman - you're memory is correct but I thought I'd provide some sample values.
    I measured the resistance on my well pump - a 1/2 hp, 240VAC, 3 wire setup:
    Black to Red - 30 ohms
    Red to Yellow - 23 ohms
    Black to Yellow - 10 ohms
    I know the resistances should add up, but there will always be some error in readings - but the numbers above give a good idea of what 'normalish' is for a working pump.
    I hope this helps.
  1. Wiring for Submersible Pump
    By techinstructor in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-06-2011, 10:49 AM
  2. wiring for deep water submersible pump
    By Skip Johnson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2011, 08:25 AM
  3. SUBMERSIBLE PUMP 110 or 220
    By loudhornsrule in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-23-2010, 10:18 PM
  4. Submersible pump going bad?
    By psyclemania in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-07-2009, 11:56 AM
  5. Submersible Pump
    By dgray in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-10-2007, 11:42 AM
