Results 1 to 3 of 3
Thread: how do i adjust softener after loosing resin
    DIY Junior Member 41fool's Avatar
    May 2012
    Texas
    Default how do i adjust softener after loosing resin
    I have a 2.0 cu.ft. Clack WS1. It softened the water perfectly on the original settings, regenerating every 2,400 gallons. Something happened a while back and water and resin flooded the garage. I think I lost about ½ cu.ft. of resin. Now, the water gets hard after about 1,800 to 2,000 gallons. What settings need to be adjusted to make the system regenerate earlier?
    Current setup:
    Program code: 20
    Capacity: 48000
    Lbs salt: 17
    The softener is 6 years old.
    You have to increase the hardness setting so the softener thinks its capacity is reached sooner, so it regenerates more often. But the smarter thing would be to replace the lost resin.
    Rather than changing the hardness, which may not do what is needed, I'd change the capacity to 40K.
    Then I'd change the salt dose lbs to 23 and do two manual regenerations with no water use during or between them.
    Then when they are done, change the lbs back to 12 lbs.
  1. What does softener resin look like?
    By SteveW in forum Plumbing Forum Discussion & Blog
    Last Post: 09-24-2011, 05:22 PM
  2. Softener resin
    By johnfin in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2011, 04:05 PM
  3. Should new softener resin need to be regenerated right away?
    By Mastiff in forum Plumbing Forum Discussion & Blog
    Last Post: 10-11-2010, 09:46 AM
  4. Used water softener has a LOT of iron in the resin
    By snuffbox in forum Plumbing Forum Discussion & Blog
    Last Post: 10-20-2008, 06:35 PM
  5. Water softener media and resin
    By Alexdc99 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-11-2006, 09:13 PM
