Results 1 to 6 of 6
Thread: t in the mainline
    DIY Junior Member tbfyou's Avatar
    May 2012
    Houston, TX
    Question t in the mainline
    I rented a 100 foot snake yesterday but have had no luck getting it in. I've watched the plumber do this before, but I wanted to get out of the deal a bit cheaper. So I drop the snake in and try to feed it into the mainline, but I have a "T" shape down there. I can not get the snake to bend enough to go into the hole. What can I do? I gotta return this machine by 12 and it is 9am now.
    ~Melissa
    Do what you should have done in the beginning. Call a plumber with professional drain clearing equipment and the skill and knowledge of how to use it. Sometime the cheap way just doesn't work.
    May 2012
    Houston, TX
    But I do not want to do that. I am perfectly capable I just need a bit of direction.
    the plumber has had YEARS of experience to get his "direction". He may also have a different kind of snake than you are using. There is no way we can tell you HOW to do it, because it is often a matter of "feel". As I asked in the previous posting, WHERE are you inserting the snake? If it is through the toilet opening, the difficulty can range from "hours of trying", to "impossible".
    You are like the customer I had a few decades ago. We were doing some remodeling and left for the Memorial Day weekend. When we returned on Tuesday, the wife asked if I could unplug the laundry sink drain because her husband had been trying to do it all weekend. he could not unscrew a pipe. I did it in a matter of a half hour or so, and as I finished, the husband came home with the biggest pipe wrench he could find, (a 36" wrench). He had rented it and was prepared to do battle with the drain that evening.
    Plumber jimbo's Avatar
    Please post a photo of the Tee and the snake you are using.
    If you have to snake a line every 6 months, there is probably a problem which is only paritally fixed each time...like roots, a belly, etc.
    If you are "perfectly capable" you wouldn't need direction. Now, I'm just a novice DIY myself, but several of the responders to your questions on both threads are highly experienced plumbers with years of experience. The advice they are giving you, essentially the same as mine, is to get professional help. This is not to call them so they can take some of your money, but to give you professional advice on your problem. Yes, this is a forum to help DIY, but not every task is suited for DIY and the best advice is to know when to call for help. Very frankly, you are not going to get anyone on this forum to OK what you are trying to do.
  1. Mainline Repair Still Leaks
    By Kiko in forum Irrigation / Sprinkler Forum
    Last Post: 09-28-2010, 07:15 PM
  2. DIY Sewer Mainline Replacement Plan
    By sctclimbs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-29-2009, 03:32 AM
  3. Mainline Lateral Pressure Loss
    By East County Grilling in forum Irrigation / Sprinkler Forum
    Last Post: 02-25-2009, 09:52 AM
  4. Mainline cleanout options
    By richrc1131 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2008, 06:52 PM
  5. Mainline tub faucet
    By LK in forum Shower & bathtub Forum & Blog
    Last Post: 08-31-2007, 06:07 AM
