Results 1 to 14 of 14
Thread: Softener not softening?
    DIY Junior Member 70runner's Avatar
    May 2012
    Riverside, CA
    Question Softener not softening?
    I installed a Fleck Twinpro 100 series (dual 8"x44" tanks) softener with brine tank about 4yrs ago. At the time I upgraded to 10% crosslinked resin to deal with the city water 1.5ppm free chlorine. My HM digital TDS meter says the city water is approx 440ppm and the softened water is about 300ppm. I checked the meter (don't have my calibration solution yet) against some bottled water, about 10ppm.
    Seems like I should be getting lower readings on the softened water, 50-100ppm. Is it time to change the media, brine tank issue?...suggestions?
    Your numbers ARE strange. It in the wrong direction. If your hard water has 400TDS then your softened water should have, say 480 or higher. Softeners add to those levels, not reduces them.
    Jan 2012
    California
    Twinpro 100... ugg, one of the less than stellar controls. It has been discontinued. Regardless, get a hardness test kit, a tds tester will do you no good. Order a hach 5B test kit.
    Nov 2010
    Maine
    I think your digital TDS meter has gone wonkey. I had one for awhile. finally bounced it off the basement wall. It didn't work any better after that either. LOL
    Now me, none of that emotional, probably from imbibing adult beverages the night before, violent stuff. I simply smiled wide as I gently laid mine in the trash one morning and wished it well in its next life.
    Nov 2010
    Maine
    Yep. I don't know if anybody makes one that is worth the plastic but the few I have had and word from others pretty much says the same thing. Surprised someone hasn't come up with an app for the I pad that does it
    May 2012
    Riverside, CA
    Appreciate the responses...
    Now that I look back on all the paperwork (memory not so good), I see that a softener doesn't necessarily change TDS, rather it exchanges magnesium and calcium ions with sodium or potassium ions (which of course most of you guys already know). The TwinFlo - dual tank approach seemed like a good idea at the time and is still going strong. Thx for the suggestion on the Hach test kit, looks like a good way to check softener effectiveness.
    Jan 2012
    California
    People complain about tds meters accuracy, than they complain that they cost more than 10 dollars. I sell tens of thousands annually, and yes, they are cheap, and yes they are junk, the price has dropped below the $10 price point. What do you want???
    BTW, I am smiling, total tounge in cheak on the thread. Honestly, I would recommend the HM digital series, these cost a few more dollars than the real cheap ones, and they can be calibrated and they actually work and are accurate. A good old fashioned analog meter (Myron L model 532T1 is over $300) is a little tought to justify when a HM digital TDS-4 is only $30.
    May 2012
    Riverside, CA
    Ditto, noticed your Riverside location...anyone around here sell the Hach5B over the counter?
    Jan 2012
    California
    I dont know of anybody that sells it over the counter. I stock hundreds of these kits, but we do not sell to end users, only dealers and manufacturers.
    http://www.amazon.com/Hach-5B-Hardne...ews/B0051V5580
    Great price for this kit.
    May 2012
    Riverside, CA
    Hach test results: supply water, 9GPG; softened water immediately turned blue with first drop. Digging back in my records I found the lab test I did prior to sizing/installing the softener. It showed CaCO3 hardness at 180ppm which would seem to be consistent with the Hach reading. Bottom line, appears the softener is doing ok.
    Nov 2010
    Maine
    Very good. Thanks for the update
    I am having a hard time understanding why Gary Slusser needs to make rude personal remarks about other members. I don't think personal attacks help anyone.
    DIY Senior Member F6Hawk's Avatar
    Mar 2012
    Alaska
    Quote Originally Posted by water solutions View Post
    Some things are beyond comprehension, you must simply accept that they "are".
  1. What does softener resin look like?
    By SteveW in forum Plumbing Forum Discussion & Blog
    Last Post: 09-24-2011, 05:22 PM
  2. Softener resin
    By johnfin in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2011, 04:05 PM
  3. Should new softener resin need to be regenerated right away?
    By Mastiff in forum Plumbing Forum Discussion & Blog
    Last Post: 10-11-2010, 09:46 AM
  4. Used water softener has a LOT of iron in the resin
    By snuffbox in forum Plumbing Forum Discussion & Blog
    Last Post: 10-20-2008, 06:35 PM
  5. Water softener media and resin
    By Alexdc99 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-11-2006, 09:13 PM
