Results 1 to 3 of 3
Thread: Ultramaxx Fusion-Welded Residential Vinyl Windows
    DIY Junior Member clearchoicewindows's Avatar
    Nov 2011
    West Jordan, Utah
    Default Ultramaxx Fusion-Welded Residential Vinyl Windows
    Residential vinyl windows have some important advantages such as: they are energy efficient, require no maintenance and they also cut the noise considerably. Even more, if you are concerned about the environmental impact of construction waste you will be happy to know that vinyl windows are recyclable.
    Vinyl windows are created from a plastic named polyvinyl chloride, also known as PVC. This material has a high R-value, meaning the amount of insulation it can provide. And that is why these windows are the popular and economical alternative to aluminum, wood, and fiberglass.
    These Ultramaxx Fusion-Welded Residential Vinyl Windows are not only beautiful, but their heavy-gauge, fusion-welded vinyl sash and mainframe structure makes them incredibly strong and tough. Years of operation and harsh weather won't diminish their quality or performance. And they offer superior resistance to the elements and to air and water infiltration. If you decide to go with these residential vinyl windows, you'll see how they will pay for themselves through lower energy costs, freedom from maintenance and increased property values and the best part is you can see your home in a whole new light-inside and out-with these windows.
    After I searched the web for some reviews. here's what I found about these Ultramaxx Fusion-Welded Residential Vinyl, based on customer's ratings:
    Pros:
    Attractive(8), Glass sealed securely(7), Good insulation(8), Opens/shuts smoothly(9)
    Best Uses:
    Decoration(3), Energy conservation(7), Lighting(5), Ventilation(5)
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Can we get a Ban with the Green Eggs and Spam mods ?
    Sounds tasty....
    Sad thing is that they are spamming a window that is pretty terribly regarded to boot.
    I don't think I would use CR to make 1 single decision about a material I would choose for my home. All advertiser driven in most cases.
  1. Fairfield 80 Series Residential Vinyl Windows
    By clearchoicewindows in forum Remodel Forum & Blog
    Last Post: 05-10-2012, 07:33 AM
  2. Excalibur II Fusion-Welded residential Vinyl Windows
    Last Post: 04-27-2012, 05:00 AM
  3. Sheffield Fusion-Welded Vinyl Windows
    Last Post: 03-12-2012, 11:04 AM
  4. vinyl windows ratings
    By anderson26 in forum Plumbing Forum Discussion & Blog
    Last Post: 02-29-2012, 08:51 PM
  5. wood windows-- alum vs vinyl exterior
    By lee polowczuk in forum Remodel Forum & Blog
    Last Post: 01-25-2008, 09:51 AM
