Thread: Soffit Vents
    DIY Member Semon's Avatar
    Oct 2011
    Tn.
    Default Soffit Vents
    I just had insulation blown in the attic space and am about to put new soffit and fascia on.
    I want to put vents at the suffix end of the roof the Styrofoam ones.
    Do I need to put one between each trust or every other one?
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Default roof vent baffles
    Use the foam or plastic baffles between all of the rafters or trusses. Also make sure the insulation is not blocking the soffit vents so you have good air flow up to the roof and out ridge vents etc.
    http://inspectapedia.com/interiors/R...ffle020DFs.jpg
    http://www.countryplans.com/images/gr9-insl.jpg
    http://i252.photobucket.com/albums/h...allbaffles.jpg
    In the trades Dana's Avatar
    Jan 2009
    Usually you'd want to put in the rafter baffles BEFORE blowing in the insulation, since putting them in after the fact is a dusty/itch PITA.
    Be sure to clear the soffit vent holes completely, and backfill the insulation evenly or you'll get cold spots (sometimes even condensation on very cold days) on the edge of the ceiling in winter.
  1. stack vents and roof vents-
    By cacher_chick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2011, 07:48 PM
  2. Exhaust fan through soffit--how?
    By Bosun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2010, 06:06 PM
  3. Inline fan to a soffit vent
    By RascalHoudi in forum Shower & bathtub Forum & Blog
    Last Post: 11-07-2009, 08:26 AM
  4. Soffit over shower?
    By Bosun in forum Shower & bathtub Forum & Blog
    Last Post: 07-24-2009, 04:49 AM
  5. Soffit
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 06-14-2006, 09:14 AM
