gojoe3
- Messages
- 70
- Reaction score
- 0
- Points
- 6
First of all, a big "thank you" to all the Pros out there sharing their time to provide information from their knowledge and experience.
I am trying to decide on the best size water softening system for our home. There are 3 people using approximately 200 gpd, 3.5 baths, 7.5 gpg compensated hardness, there is the potential for the peak flow rate to reach the 9 to 12 gpm range.
I have been researching how to best determine what size unit to purchase and am still in a quandary and need to replace our system fairly soon. From my recent research, I understand that for our consumption pattern and our well water condition, if I get a 1.0 cu ft unit using a Fleck 5600SXT and set it to use 6 lbs of salt, it will regenerate approximately once a week. This would seem to be an efficient use of salt and would be good for the resin's performance and maintenance. I would need to accept that if we occasionally exceeded the stated peak or maximum service flow rate of the resin, that hardness will break through. From what I understand, 1.0 cu ft of 8% crosslink resin can handle a maximum service flow rate of 9 gpm. If I wanted to get a higher max service flow rate of 12 gpm, I would use 1.5 cu ft of resin, and using a 6 lb salt setting would use 9 lbs of salt per regen but this would not regen within the optimal timeframe for a healthy resin bed and could lead to channeling. So, I assume I would need to set the override on the Fleck to regen every 7 to 8 days and I would be using 9 lbs of salt per week instead of 6 lbs (for the 1.0 cu ft unit) in order to get a higher service flow rate thus potentially avoiding hardness breakthrough. I would be using more salt and more water to regen the 1.5 cu ft unit. This seems like it would not be an efficient use of salt or water to get a higher max service flow rate but may be necessary to maintain the resin bed properly and to potentially avoid hardness breakthrough.
Sorting through all the information and opinions on the internet and from local water conditioning professionals to come up with an answer to the question "what salt setting should be used if I want to regen every 8 days and use salt efficiently and effectively for a 1.0 cu ft unit?
For a 1.25 cu ft unit?
For a 1.5 cu ft unit?
consuming 1400 gallons of water in 7 days with a compensated hardness of 7.5 gpg?" has been a real challenge.
I'm considreing going with a 1.0 cu ft system using SST-60 resin (for its claimed potential higher flow rate capabilities and salt efficiency), set to regen using "X" amount of salt ((to be determined)(any suggestions)) with the override set for every 8 days. I understand that if I exceed the max SFR of "X" (7 gpm? 9 gpm? still researching) that hardness will breakthrough.
I had a comprehensive water test from a certified independent lab done for the water from the well and one for after the existing softener, a week ago. The compensated hardness number I used to estimate what size system I would need is 7.5 gpg (6.5 gpg hardness + 1.0 for .01 mg/L iron). Manganese = ND. The pH is 6.7. I understand that the pH is a bit low but will probably not add a neutralizer at this time. I rounded the 7.5 gpg off to 8 and the water consumption is rounded off to 70 gpd per person. I calculated that 210 gpd X 8 gpg X 8 (7+1 for reserve)days between regenerating = 13,440 grains to be removed. I rounded this off to 14,000 to estimate that I would need 1.0 cu ft of resin to remove the hardness from our water. The problem is that 1.0 cu ft of resin may not be able to remove the hardness when our maximum flow rate exceeds the resin's capacity. So, I would like to know if a 1.25 cu ft system or even a 1.5 cu ft system would be more appropriate.
I was guessing that using SST-60 with a less than optimum sized system would support higher flow rates with less salt and water consumed for regenerating, even though iron is not a concern. Is iron a concern at .01 mg/L? I will be installing the system myself and the SST-60 is available locally for approximately $30 per cu ft more than standard 8% crosslinked resin.
I may consider adding an acid neutralizer but the space is really tight. It is literally a water closet in a finished basement which contains the well pressure tank and the existing cabinet style softener. I will already be using more of the existing space for the two tank softener. I understand that if I install a neutralizer now, or in the future, that it will add some hardness (how much?) and that I will need to size the softener appropriately.
How would I go about correctly sizing the pH neutralizer? Would one use a time clock based control valve and a 10x54 tank with a dome hole? Calcite only or a blend with corosex, and quantity of each?
Any guesses as to the approximate rise in hardness I can expect?
Will I need to use Iron Out or similar for .01 mg/L?
Can .01 mg/L of iron potentially foul the resin bed if set up for an 8 day regen?
Does SST-60 work better in a larger quantity?
Thank you for your assistance.
