Page 2 of 8 FirstFirst 12345678 LastLast
Results 16 to 30 of 114
Thread: Las Vegas Water Softener Selection
  1. #16
    Jan 2012
    California
    If you have that controller, it is one of Culligans best. It is a proprietary 7000 valve by Pentair, and Culligan has some special programming to make it slightly more efficient. That system is definetly worth repairing. What are the sysmptoms of what it is doing?
  2. #17
    DIY Member John Vegas's Avatar
    May 2012
    Las Vegas
    It is dripping through the drain line. I have literally been shutting off the water at the shutoff when I go to work and go to bed for like 2 months and am getting tired of doing it. I should just call Culligan to repair, but I really don't like the local dealer.
    JS
  3. #18
    Jan 2012
    California
    I have a very good freind in Vegas who can help you out, let me know if you want his information.
  4. #19
    May 2012
    Las Vegas
    Please check your email.
    Thanks, JS
  5. #20
    May 2012
    Las Vegas
    Default Culligan Regeneration
    Ok, so I am having loads of luck with this Culligan.
    For some reason, the GFI keeps tripping in my garage. When it trips, it turns off the Culligan. I am going to replace the GFI tonight (this house seems to have electrical gremlins), but is there a way to prevent the Culligan from regenerating? It has regenerated the past two days in a row because I don't know how to make it stop (or even if I can!!!).
    Thanks, JS
  6. #21
    Nov 2010
    Maine
    I'll be crucified for this but I hate plugging water filtration equipment into GFCI breakers or outlets. The damn things trip and screw up the timer and it turns into a service problem which turns into having to get an electrician in which turns into a pissed off customer. Still, code is code is code is code.................................
  7. #22
    May 2012
    Las Vegas
    Oh yeah, If I can fix this, i am removing the GFI totally. To hell with the code, I can't have this damned softener regenerating every night.
    I probably need to buy some load testing device or something to test some outlets. I think this house was wired incorrectly because this is not the only GFCI issue I have had. That, or DR Horton used el cheapo GFCI outlets and they are starting to malfunction, especially since the garage here gets to about 125 degrees in the summer!
  8. #23
    Jan 2012
    California
    I would update the GFCI outlets to new ones. Name:  7018k15p1l.png
    Test every plug in the house with this to make sure they are wired correctly.
    http://www.terrylove.com/forums/show...ight=prototype
    If you look at this thread, the picture shows every outlet is outdoor protected as well as being GFCI, never a problem here. Anytime I have an outlet near water (execpt in the kitchen on the counter, I put one of these covers on.
    sorry about posting the cheat sheet, I hit the wrong file.
  9. #24
    May 2012
    Las Vegas
    I put a new GFCI outlet in, but I didn't plug the softener back in since I know that I'll have softwater for several days. I wanted to see if something else might cause the GFCI to trip (I only have an irrigation time on the circuit and I ran that through its motions turning on all the valves and no tripping).
    I assume I am not doing any damage to the softener if I leave it turned off and NOT in bypass mode?
    JS
  10. #25
    May 2012
    Las Vegas
    Quote Originally Posted by John Vegas View Post
    JS
    I hope I have not done any damage as I just turned it back on today to regenerate.
    JS
  11. #26
    Nov 2010
    Maine
    It should be fine. Re-set the programming if needed
  12. #27
    May 2012
    Las Vegas
    I thought I had a Platinum Plus, which is clearly the Fleck 7000SXT valve. The valve diagrams are exactly the same (as posted on the Fleck and Culligan websites). I now realize that I have a Platinum series valve. Culligan has apparently not posted a valve diagram for this model, which is extremely frustrating!
    I have reviewed the cut sheets for nearly every valve made (Fleck, Autotrol and Clack) and none of them seem to match the look of this Culligan valve.
    Does anyone have any idea who manufacturers this valve? I guess it is possible the Culligan made a special valve, but at least the internal parts are usually consistent (especially since the Platinum Plus is clearly the 7000SXT.
    Thanks, JS
  13. #28
    May 2012
    Las Vegas
    So I have been living with this dripping to drain water softener for months now, LOL, but it is getting worse. Can anyone identify this valve or any suggestions on how to get to the seal pack? I poked and prodded the thing by removing some screws and the plate on the left (which seems to give access to the OTHER end of the seal pack assembly. It seems like you need to take off the mechanical contraption on the right to access the correct end of the seal pack, but not sure. Its JUST about time for either a repair man or a new system...
    Thanks, JSName:  Culligan 1.jpg
Size:  42.0 KBName:  Culligan 3.jpg
Size:  42.2 KBName:  Culligan 2.jpg
  14. #29
    Jan 2012
    California
    Sadly, I vote for a new system. That is definetly a proprietary unit, not the 7000 variant. Your Culligan rep should be able to repair it easily and at a reasonable price. If not, then it is time for a change. (timely, just a couple weeks away, time for a change)
  15. #30
    May 2012
    Las Vegas
    Default Connecting new system...
    So I am thinking about pulling the trigger on a new 48K Fleck 7000SXT. My only question for now is how would y'all suggest I connect the system? As you can see from the previous pictures, I have those odd flared fitting that connect the existing POS Culligan. I can get the Fleck in just about any size from 3/4 to 1/5" plastic fittings.
    I don't have the tools to solder, and I am hoping to avoid calling in a plumber (although I can pull a favor if I need to). I was thinking it might be best to just cut out the flared fittings (I do have a copper pipe cutter), put on on a push connect fitting to transition from the copper pipe to threaded. I was figuring using a push fitting to go from the 1-inch pipe to 1-inch threads, order the softener with 1-inch threads, and then use flex connectors to basically connect the pipes (inlet and outlet) to the softeners.
    Is it standard to connect softeners with flex connectors rather than hard plumbing like the Culligan (see pics earlier in this thread).
    Thanks all, JS
  1. Softener Sizing and Selection
    By NYRich in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-06-2012, 09:22 AM
  2. Water Test and Softener Selection
    By jimt2007 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-17-2011, 03:36 PM
  3. Water softener selection help
    By chris1044 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-11-2010, 05:00 PM
  4. Softener Selection Help
    By skidoddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-03-2009, 09:06 AM
  5. Water Softener Regulations in Las Vegas
    By rkkerezsi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-26-2008, 11:59 AM
