Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Shower Mixing Valve Replacement Advice
  1. #16
    I can't look up the wall, but it looks like 3/4" air chambers to me. I bet they have caps on them and they are about 16" long.
    I would cut near the valve, and use couplings on the 1/2" pipe to the valve. It looks like you have some room to push the pipes apart there. You're almost done now.
  2. #17
    DIY Junior Member lkstaack's Avatar
    Sep 2011
    San Diego, CA
    Thanks, Terry. If I understand you correctly, the job will be alot easier than I thought.
    You are saying that I only need to cut the 1/2" pipe at the old valve and use couplings? I will be able to slide the couplings up the shower/tub pipes, so that is not an issue. However, you think that I will be able to bend the 3/4" pipes far enough to fit in the couplings in areas marked A and B on the attached pic? I'll only have about 1/2" of copper pipe coming off the 3/4" pipe after cutting off the old valve and another 1/2" coming from the new valve. Is that enough material to get a good solder connection?
  3. #18
    I think you will find that when the pipe is cut, that you will be able to move the copper pipes enough to work on that. You may need some short pieces of pipe to make up the difference. You will want to remove the water in the line, maybe a vacuum will do that.
  4. #19
    Sep 2011
    San Diego, CA
    Thanks. Won't the water drain out of the cut pipes and open faucets inside the house?
  5. #20
    It looks like the pipe dips down below the valve.
  6. #21
    Terry's point should be investigated! WHere does that pipe go when it goes up? If it is just a stub that is capped, it is a waste and you can eliminate it entirely. That would make it much easier.
  7. #22
    Sep 2011
    San Diego, CA
    Default Valve Fitting Advice
    I request valve fitting advice. As you can see, I've cut off the old valve and have around 1/2" clearance between the 4 pipes and the new valve. I was expecting to slide the couplings up the top and bottom pipes and then slide them down when the new valve is in place. However, the couplings don't want to go further than about 1/2 their length. Is this how you are supposed to fit the valve?
  8. #23
    I would think that the pipes to the side will move outward, allowing insertion into the valve. You may need to go beyond the studs and work from the verticals coming down.
    The tub spout can go in last if needed.
    But you're committed now. Chop out whatever you need to get that thing in there.
  9. #24
    DIY Member jadziedzic's Avatar
    Aug 2006
    New Hampshire
    You are using couplings with a "stop" that prevents them from sliding more than half-way onto the pipe; get couplings without the stop (aka a "repair coupling") and you'll be all set. You'll have to be sure that the coupling is held in place (with a screwdriver perhaps) when you solder those joints so the coupling spans each pipe about the same amount.
  10. #25
    A repair coupling does not have a stop in the middle, so you can slide it anywhere you need, then slide it back to, ideally being centered around the two pieces of pipe. Keeping it there while soldering can sometimes be a pain, especially on the verticals so maybe a vice grip to hold it, or bend it slightly so it stays in place
  11. #26
    Sep 2011
    San Diego, CA
    Default Do I have to start over?
    I completed the valve installation only to find during pressure testing that I neglected to solder one each coupling joint to the tub and shower pipes. When I went back to solder the two joints, I found that the joints wouldn't suck in the solder. Did the leaking water affect the flux? What are my options besides starting over?
  12. #27
    Water will wash out the flux.
    No worries. Just disassemble, clean up, flux and solder.
    It's part of the learning process. We've all done that.
  13. #28
    Sep 2011
    San Diego, CA
    Crud. Assembly was a bitc*. Disassembly and reassembly will be a pain too. Well, like you said, its all part of the learning process. Thanks Terry.
  1. Waterworks, Sigma, Can't identify faulty shower mixing valve?
    By johnsas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2013, 06:45 PM
  2. Bad Sterling Mixing Valve in Shower
    By Tleast in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2011, 07:14 PM
  3. Need new shower/tub mixing valve
    By Scuba_Dave in forum Shower & bathtub Forum & Blog
    Last Post: 10-26-2009, 11:17 AM
  4. Need to replace Shower mixing valve with separate cutoff valve for inputs.
    By OfficeLinebacker in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2006, 09:06 AM
  5. Pegasus mixing valve for shower.
    By canton in forum Shower & bathtub Forum & Blog
    Last Post: 02-20-2006, 04:22 PM
