Results 1 to 15 of 27
Thread: Two inch well question
Hybrid View
    DIY Junior Member pjsteel's Avatar
    May 2012
    Georgia
    Default Two inch well question
    I have an old two inch well (galvanized casing) that I need to replace inner piping, foot valve, packer, jet, etc.
    I am at he point of pulling out the old piping. My question is: Is the casing adapter threaded to the casing or is it just seated to it? I am assuming that it is just seated but before I go to yankin' I thought that I would ask you guys. I remember replacing the pipes years ago with my dad but I can't remember how it is assembled exactly. My dad has since passed.
    Thanks,
    Phil from Georgia
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    Depending on the brand, it may be threaded but most likely it is sealed by 2 or 3 bolts.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    May 2012
    Georgia
    Quote Originally Posted by Porky View Post
    Yes, it has 3 bolts with a rubber gasket(seal) in between.
    So I guess I can assume that it is not threaded.
    DIY Junior Member liam o k's Avatar
    Sep 2012
    indiana
    my situation is the same as phil's in georgia. i removed the three bolts and inserted eye-bolts with chains, and proceed to pull with a come-along. i eventually raised the pipe about an inch and a half, then it stopped. the 4x4's are groaning, i can't get another click on the come-along and i fear the cable snapping. do i need more muscle, or is there something i need to know?
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    let off the tension a little and try to spin it with a wrench (clockwise only, as to tighten). if nothing still, tap it down a little.. spin it and try again. usually the leathers are hanging you up, so the more you wear them out, the easier it should be to come up.
    btw i'd advise pulling from the 1" threaded hole on top of well adapter. careful not to break those 3 bolt holes.
    Sep 2012
    indiana
    after two hours of doing as you said (giving up twice) it worked!!! thanks, justwater. i quite easily pulled up thirty feet of pipe (water at eighteen feet) to find a clear venturi and a foot valve that seemed to work, though i can't be sure there wasn't debris in it before i messed with it. so i still don't know why the pump wasn't holding a prime. what else could it be.
  1. we have a 16 inch rough-in andcannot find a tolet ith a 16 inch roughin anywhere
    By nancyann in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2011, 04:22 PM
  2. Another 4-Inch versus 8-Inch Sink Drill Question
    By RonnyK in forum Remodel Forum & Blog
    Last Post: 01-27-2009, 09:45 AM
  3. Cable tool or bore drill? 5 inch pvc or 4 inch steel?
    By Barnes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-16-2008, 05:48 AM
  4. Question about mixing 4 inch pipe types?
    By SteveL720 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2007, 07:12 PM
  5. Problem flowing 4 inch PVC into 3 inch cast iron?
    By skip in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-26-2005, 07:03 AM
