Results 1 to 5 of 5
Thread: No cold water in the shower
Hybrid View
    DIY Junior Member fabs's Avatar
    May 2012
    Denmark
    Default No cold water in the shower
    Hi,
    Over the last few weeks, the water temperature in my shower has been rising gradually. At first, the solution was simply to lower the temperature but now I'm afraid that something else needs to be done. Even when set to the coldest temperature, the water that comes out of the shower head is scolding hot. I've been living here for 1,5 years and this is the first time something like this happens. I can still get cold tap water.
    I live in an area with lots of calcium in the water (I need to put water softener in the dish washer regularly).
    Please find attached a picture of the blender (make: Grohe).
    I hope that you can help!
    Kind regards,
    Fabian
    May 2012
    Denmark
    Is it OK to tap/hit the valve with a hammer to loosen up whatever's inside? Is there a chance that it would help? I've tried turning the temperature setting up and down quickly which makes the water a little bit colder and increases the water pressure, however the general temperature is still much hotter than what it should be. This together with fact that it has changed gradually makes me a bit perplexed as to what it is that's causing the problem.
    Is the flow even between the two handles?
    If not, you might want to open the valve up and see if it's blocked.
    May 2012
    Denmark
    Thank you for your answer.
    The left handle controls water pressure and the right one controls temperature, but I think that the flow is uneven. Can the calcium in the water block valves? I need to call a plumber if I want to turn the water off so I'm trying to fix this without opening anything up. Do you think that's possible? I appreciate the help.
    On many Grohe valves, they have water filter screens on the inlets to the valve. The cold screen could be nearly plugged up with crud. If that isn't it, then the thermostatic cartridge is shot and likely needs to be replaced. Both would require the water to be turned off to access and repair or replace.
    If the screen IS plugged up, then you should try to figure out with what so you can try to solve the issue that caused it.
  1. No cold water in shower
    By nzstorm in forum Shower & bathtub Forum & Blog
    Last Post: 06-28-2010, 07:12 AM
  2. Shower has hot but no cold water.
    By firsttimehomeowner in forum Shower & bathtub Forum & Blog
    Last Post: 05-05-2010, 09:40 AM
  3. no cold water in shower!
    By KMRyan1985 in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2009, 04:02 PM
  4. no cold water from shower
    By patvoyles in forum Shower & bathtub Forum & Blog
    Last Post: 08-18-2008, 12:14 PM
  5. Shower water used to be hot, now it's cold
    By Dan Russell in forum Shower & bathtub Forum & Blog
    Last Post: 02-16-2007, 09:18 AM
