Results 1 to 7 of 7
Thread: Delta handle question - Trying to remodel a delta 3 handle bath valve system
    DIY Junior Member keithwwalker's Avatar
    May 2012
    Portland, OR
    Question Delta handle question - Trying to remodel a delta 3 handle bath valve system
    Hi
    I have a real old Delta 3 handle bath/shower valve system. The job started out just with replacement of the shower walls and since I was in there, it made sense to replace the valve cartridges and spring/seals so that it would be good for a long time.
    Then I decided that if I could replace the plastic 'crystal' knobs with something more up to date, that it would be really great. Those plastic pieces don't hold up well. This is where I need some help.
    It has been really hard finding information about the existing system on the internet, so I will describe it as best I can with the help of some hyperlinks.
    So my system is essentially shown as system D on the 4th page of this pdf:
    http://www.plumbingpartsdepot.com/dela23handtub.pdf
    First question:
    It appears that H24 levers can be used on this system (see page 2 of pdf). How are these levers different from H64 levers?
    Delta H24NN
    Delta H64NN
    Second question:
    I am having trouble figuring out which escutcheons and sleeves to use for the H24 levers. The old crystal handles had a stem and cover plate as shown on page 4 of the pdf and the stem protruded into the crystal handle.
    Those stems are about 2 inches long and stick out about 1 inch from the wall, such that the new H24 levers will not meet the escutcheon. I believe the proper escutcheon to use is the RP23094nn
    Is there a shorter stem that will work with the H24 levers?
    I purchased replacement stem sleeves RP18136, but they are too long too (same length as the old stem sleeves):
    The RP23094nn escutcheon that goes with the H24 levers is a face mount, and its thread doesn't appear to travel far enough in to meet the RP18136 sleeve thread.
    Is there an adapter that can be used?
    KWW
    Plumber jimbo's Avatar
    You found a pretty good resource there. Bottom line for sure is you need to get the set...escutcheon, extender,sleeve, handle...that are specified to go together. I can't tell you for sure that every set fits every rough in. Definitely there is only ONE stem, just different extenders
    You might also find that not all those parts are available. Most of that is NOT available from Delta anymore, but the aftermarket companies still make some of it.
    I'm assuming this is a hot/cold/diverter setup? If so, you really should consider replacing the whole thing with an entire new valve (if it is used as a shower as well) with one meeting todays federal anti-scald regulations. Depending on where you live, the mods you are making qould require it during this remodel to get a building permit (which is also likely required).
    May 2012
    Portland, OR
    Yes it is a hot/cold/diverter setup. The goal is to replace the valve cartridges, and levers; but not the rough in (it is in good condition). I don't believe that a permit is called out for cartridge replacement.
    A lot of places would say that opening the walls constitutes a remodel and would call for upgrade to current code. We are not the code police, so knock yourself out. But consider where you are TODAY: wanting parts for a valve which has been out of production for 10 to 15 years. Some ability to repair leaks...limited availability of handle parts, etc. Where will you be 10 years from now, with your new tile walls which you hoped would be undisturbed for 25 years? THAT is why we suggest a new valve./
    New valves are pressure balanced or thermostatically controlled. The old two and three handles valves don't have that.
    Not only is it going to be harder and harder to find the parts for the old valves, they just weren't that good to begin with.
    May 2012
    Portland, OR
    All I wish to do is change the handles.
    The parts are still obtainable, and the replacement valve seals and cartridges are already installed.
    There is also an existing tempering valve by the water heater.
    fwiw, I have found some answers:
    The H24 handles are generally for sinks, and the H64 are generally for roman tubs. The rough ins are fundamentally different (horizontal vs vertical stems), so I am probably stuck with replacing the existing handles in kind.
  1. Delta 600 up/down single handle shower valve?
    By Kognyto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-10-2011, 02:33 PM
  2. Delta Single Handle Leak + ID
    By ryardson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2010, 10:42 AM
  3. Delta 2 handle bath faucet (3555) - leaking from under spout body
    By PeteD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2010, 08:09 AM
  4. problemes with water flow on delta one handle valve
    By erich in forum Shower & bathtub Forum & Blog
    Last Post: 02-26-2008, 12:43 PM
  5. Delta single handle won't turn off
    By markrwolfe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 07:28 PM
