Results 1 to 3 of 3
Thread: 240V Timer Switch
    DIY Member K2's Avatar
    Jul 2008
    Delridge Valley
    Default 240V Timer Switch
    Hey guys,
    I need a bit of help understanding a diagram. I want to hard wire my 240 circuit to a timer, then wire the outlet from the timer, I don't want to assume with this one
    I'm hoping the L and 1 are the hot supply, and the X and 2 are the line TO my outlet.
    Question is, do I have to put jumpers on each L to X and 1 to 2? Or is this thing wired to know that switch will kill power to X and 2 when it's not active (per the timer)?
    thanks in advanced!
    Name:  240 Timer Schematic.jpg
    If you added jumpers, you'd be bypassing the switches controlled by the timer motor...when the timer is set to enable the load, the contacts get moved so it connects to the hot terminals automatically.
    Jun 2007
    North Carolina
    Use the diagram on the left. Line lands on L and 1 while the load (outlet) lands on X and 2
    http://www.smarthome.com/manuals/59309-ins.pdf
  1. Reliable timer switch for wells?
    By ballvalve in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-27-2010, 03:31 PM
  2. Timer switch for bulb heater blown
    By 98ZJUSMC in forum Electrical Forum discussion & Blog
    Last Post: 06-25-2010, 12:52 PM
  3. 240v 2 pole grounding switch to receptacle
    By RileyD in forum Electrical Forum discussion & Blog
    Last Post: 04-08-2009, 04:36 PM
  4. New Bathroom Fan Timer Switch
    By draven8795 in forum Electrical Forum discussion & Blog
    Last Post: 04-02-2009, 07:01 AM
  5. Outdoor 3-way switch and timer
    By Hillel in forum Electrical Forum discussion & Blog
    Last Post: 11-20-2007, 11:24 AM
