Results 1 to 6 of 6
Thread: Moen shower valve moans
    DIY Junior Member ahosh's Avatar
    Feb 2012
    Westchester, NY
    Question Moen shower valve moans
    Hey Guys,
    I have a Moen shower valve in my home's main bathroom. I am currently renovating my master bathroom and to re-run soem plumbing and rough in the new shower valve, I had to turn the main house valve on and off a few times. Now the Moen shower valve in the main bathroom moans when I move the lever to the hot side. It is a single handle and it seems to make the moaning noise anywhere along the warm water side.
    Any ideas why or what I can do to fix it?
    Andrew
    DIY Senior Member JerryR's Avatar
    Jul 2011
    Florida
    Quote Originally Posted by ahosh View Post
    Hey Guys,
    Andrew
    Call Moen at 1-800-289-6636 Describe the problem to them and they will send you a free replacement cartridge kit.
    Just had same problem.
    Jerry
    JR
    Jul 2009
    North Vancouver, BC
    Good answer Jerry!
    JW
    The problem with that answer is that if it is a Moentrol valve the noise could be in the pressure balancing spool and a new stem will not cure it.
    Jul 2011
    Florida
    I just got around to replacing my Cartrige. Last week I attempted to break it free with the plastic "tool" included in the kit. No way would it budge. I called Moen and they sold me the REAL TOOL for $25 and shipped it FedEx.
    I sprayed the old Cartrige with some PB Blaster 2 days ago. Tonight, With the REAL TOOL it came out. That tool works like a bearing puller where you can apply pulling pressure and at the same time slightly twist the cart. That did the trick.
    JR
    Jul 2011
    Florida
    Mine was a positemp from 2001.
    JR
  1. Problems installing Moen shower valve.
    By kskier in forum Plumbing Forum Discussion & Blog
    Last Post: 07-11-2010, 06:39 AM
  2. Moen shower valve woes.
    By Scrapshooter in forum Shower & bathtub Forum & Blog
    Last Post: 02-08-2010, 05:29 PM
  3. Moen shower valve install
    By Davebutch in forum Shower & bathtub Forum & Blog
    Last Post: 05-21-2009, 06:07 AM
  4. moen shower valve problem
    By joe617 in forum Shower & bathtub Forum & Blog
    Last Post: 06-19-2008, 07:34 PM
  5. Moen Monticello - New Shower Valve Leaking?
    By queenofthetile in forum Plumbing Forum Discussion & Blog
    Last Post: 03-27-2008, 05:09 PM
