Is the screw installed in the anchor? If so, remove the screw, or loosen it. Those are designed to bulge out as you tighten the screw in them, expanding to hold it in place in the hole. If the screw is installed, it's already expanded - it will lengthen and get slimmer when you loosen the screw.
