Results 1 to 8 of 8
Thread: Circuit Breaker Lockout for Exit Signs?
Hybrid View
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Default Circuit Breaker Lockout for Exit Signs?
    OK, yes I will ask the fireman that wrote this up when I can get ahold of him, but I wanted to ask you:
    The Fire Marshal just inspected a fairly sizable Mall near me, and as fate would have it, I know one of the merchants who got tagged. Apparently almost everyone got the same to-do list.
    Get the exit signs tested by an electrical contractor. OK. Get him to certify what you have works or get it replaced. OK. Figure out which breaker in the panel feeds it. Well, OK. If you insist. Mark it as such. Well, sure, while we are at it, yeah.
    Now. Provide a "lock out". I don't get it. My thinking on lock outs is their utility in a large industrial plant where there is frequent need to shut down power to something that is well out of view of the panel.
    Why would anyone need to "lock out" an emergency exit sign? Why would you ever need to deliberately turn it off. Unless you were replacing it, but the the logic applies to all the circuits in the store, yes?
    He doesn't want it accidentially turned off, i.e. a deliberate action must be required. It's possible that in doing some maintenance, the operator might just turn multiple things off just when they are needed the most.
    Jan 2012
    Los Angeles, CA USA
    OK, I need to find lock-outs that can lock the toggle in the on position. Obviously the breaker can still trip even if the toggle is locked.
    Hmmmm. I wonder how universal lockouts are? I've not needed to install any before. Most of the panels are three phase......
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    You don't need to use the kits for lock-out/tag-out. A breaker lock would work.
    Here is one style.
    http://www.garvinindustries.com/Devi...echanisms/UBL1
    Besides the "universal" breaker lock out, each manufacturer has those specific to their breakers. Exit signs, emergency lights, and "local fire systems" all need lockouts to prevent them from being disabled by flipping the breakers. They do not "deliberately" get turned off, but if someone is looking for a particular circuit, they WILL turn off every breaker and may forget to turn the safety ones back on. The lock out prevents them from turning it off, unless it is the one they are working on, in which case they remove it and hopefully replace it when they are done.
    Jan 2012
    Los Angeles, CA USA
    Sounds straightforward.
  1. Circuit Breaker Question
    By eric3872 in forum Electrical Forum discussion & Blog
    Last Post: 07-02-2011, 06:48 PM
  2. Circuit breaker keeps tripping
    By cluesmom in forum Electrical Forum discussion & Blog
    Last Post: 04-05-2009, 04:49 PM
  3. circuit breaker question
    By floridian in forum Electrical Forum discussion & Blog
    Last Post: 01-30-2009, 02:59 PM
  4. Problem with circuit breaker. HELP!
    By spartanic in forum Electrical Forum discussion & Blog
    Last Post: 10-28-2007, 04:50 PM
  5. Circuit breaker tripping on well
    By SteveFromMass in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-05-2006, 10:24 PM
