Results 1 to 8 of 8
Thread: Automated Pure Water 12"x60" Retention Tank - Good stuff or BS?
    DIY Junior Member Muff's Avatar
    Apr 2012
    nothern wi
    Default Automated Pure Water 12"x60" Retention Tank - Good stuff or BS?
    Anyone out there using the Automated Pure Water retention tank? I'm tight on space and this product sounds to good to be true. A 12"x60" tank that out performs a 120 gal. tank. The design kind'a makes sense .
    Nov 2010
    Maine
    I have no experience with it and although the claims sound impressive there is a lack of operational information on the site that makes it difficult for me to be able to judge whether or not it is a viable product. If their warranty backs up their claims and the cost is not ridiculously higher than a standard tank then I suppose it's worth giving it a try.
    Nov 2005
    Central Florida
    You can view the patent on this gadget at http://www.google.com/patents/US7600911, which describes the inner workings in excruciating detail. My only concern is that the smaller time spent in the tank might not allow adequate time for contact (to kill microorganisms). I'm also not convinced that there's adequate time for settling, in spite of their claims -- gravity only works so fast. They might have lab test data available
    I sold hundreds of them over about 10 years and never had a problem with any but one broken bottom drain elbow the customer broke.
    When you thoroughly mix a disinfectant into the water stream to be disinfected or for oxidizing H2S, iron etc. etc., the contact time required is greatly reduced.
    The dirty water getting out of all retention tanks must be filtered but, the design of the bottom end of the distributor tube causes most of any sediment to fall to the bottom of the tank.
    IIRC the product has been on the market for 15-20 years and mostly is sold to dealers by the manufacturer and that doesn't happen if a product doesn't do as claimed.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I to have not used one of these tanks but I can see where it has a better mixing ability over the standard retention tank. If you think about it, an injection pump injects, has a pause, then injects again. The whole time water is passing the injection point. Injecting into a chamber where the water is churned up will have a quicker mixing which starts the disinfection sooner. Thats how I see it.
    Nov 2005
    Central Florida
    Doesn't look like injection occurs in the fancy tank -- the tank just mixes up the injected water. I've already got a tank, so I've asked them if they'll sell just the swirly thing.
    Update: I had a nice conversation with the inventor of this gizmo. Turns out the tank I've got already has the swirly-thing in it, hidden in the tube, so I'll give it a try and accumulate some experience with it.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Mikey View Post
    ...I've asked them if they'll sell just the swirly thing.
    Looks like they have the chem mixer available as an in-line device.
    http://www.apwinc.com/chemmixer.html
    Nov 2005
    Central Florida
    That looks something like it, but it's missing the bottom baffle, which is needed in the in-tank application. I could probably just add the in-line mixer between the injector and existing 120-gallon steel tank, but I like the bottom-drain blowdown feature of their tank. The steel tank's drain is above the bottom, and not very effective in blowing out all the residue.
    Update: It turns out that the tank I've got IS the tank we're talking about, with the swirly thing hidden inside the tube. I'll let you know what I think about it after I've accumulated some experience with it. For a couple hundred bucks you can add a timed valve on the bottom drain to automatically clean out the accumulated crud.
  1. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2013, 09:34 PM
  2. not "stuff", just "computer"
    By jimbo in forum Computers and Stuff
    Last Post: 03-14-2011, 11:19 AM
  3. need a list of "new stuff" to buy.
    Last Post: 11-14-2010, 07:42 AM
  4. The "stuff" in the P-trap.
    By Artie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-22-2009, 09:50 AM
  5. Not computers, but "stuff"!!
    Last Post: 03-31-2008, 12:15 PM
